Question about Evga e-GeForce 8600GT, GeForce 8600 GT, Graphic Card
Shakeelm, the monitor doesnt have a signal so it must be the graphics card? ive tried working memory in the slots and the beeping is still happenig
  • 81 Answers
You have lose contact with your port of the graphic card just change the card if you hve warranty
Posted on Mar 03, 2009
Continuous beep beep beep noise.
The Video (Graphics) Card inside the computer is not working. The fact that the monitor displays NO Input Signal shows that the monitor is working. Try connecting another monitor to the computer and you'll get the same NO Input Signal messaged because the monitor is not receiving a signal from the computer as an input source. Also you can try your monitor on another computer just to validate that it is ok.
Jun 02, 2012 | Compaq Presario SR5710Y PC Desktop
Why is my computer making a beep noise then a long beep and doing it all over again when if starts up
the beeping is a warning when some of the devices are not working right ..If it is all OK ..it should beep one or twice ..depending on the ram memory ..and start ..or not beeping at all ..but if it does that it is either the ram memory to blame ..(check it by removing it and try to boot with one module at the time and this way locate the guilty one if this is the cause )..
Another thing for this behavior is the graphic card ..If you have a separate agp or pci one ..and not on board (included) ..just remove the graphic card ..and place it again and press it firmly in the slot ..After that try to restart again ..If it works it means it wasn't making contact ..but if it does not ..you should consider other card ..If it is the card to blame the display would show the no signal message ..(if the card works the no signal is not present cause it has signal (even black ) from the card ..
If your computer have a on board video card ..and the agp/pci one failed..you can remove the other one ..and hook the vga cable to the on board one ..and restart and will actually work with it ..but only after you remove the one in the slot .
Have a nice day ..and don't forget to rate my answer..!
Dec 19, 2011 | Computers & Internet
My monitor samsung 2330 keeps saying check digital signal cable and I've put the cords all in the same way I had them before and now this screen keeps popping up
If you already check your connections and still no answer from what you're doing, do these steps:
  1. check for any beep codes
  2. remove and reinsert your RAM to another memory slot, if it works you have a problem with your RAM, you'll need to buy a new RAM that is compatible with your motherboard
  3. if you here a 1 short beep, that means it already start the booting sequence of your computer but you don't see any boot screen and still the out of range error. You have a defective graphic card.
  4. Is your monitor is a LCD type? if your answer is yes that means your monitor is not compatible with your old graphic card, buy a new graphic card that is compatible with your motherboard and to your LCD monitor. Because old graphic cards or onboard vga cannot hold much more pixels than newer ones that's why you have an out of range error
Aug 01, 2011 | Samsung Computers & Internet
I start my computer up and i get 3 beeps and a black screen!
Three beep usually mean there is a ram issue. The computer is not passing the post. To resolve this issue I would first try to reseat the ram. Basiclly you will remove the Ram and place it back in the same slot. If this fail, place the ram in another slot.
Jul 11, 2011 | Computers & Internet
Beep and blue flashing light monitor states going to sleep
in that case you need to open the tower or CPU and reseat RAM and graphic card if you have 1
and then try to start the computer
it should work
and if you still get beeps.
and can try to plug memory card 1 by 1
if you have more than 1 memory card
if the computer starts with 1 memory card
then it could be the issue with the memory card
if not then the slot on the motherboard is gone bad
and the motherboard needs to be replaced or repaired
Mar 28, 2011 | Medion MD-1704 PC Desktop
My compaq presario sr1000 computor won't stop beeping from the inside and it says no signal on the monitor
1 short beep and 1 long beep means its a memory problem.
Shut down your computer, then open your computer case and replace the memory module.If you have 2 or more modules ,try starting the pc with one.If it fails, try a different single module.
2 short beeps and 1 long beep repeating for 5 times means its a graphics card issue.
Shut down your computer, then open your computer case and unplug the graphics card, then plug it again.If this doesn't help, try with a different(confirmed working) graphics card.
Mar 13, 2011 | Computers & Internet
Lights and Fan are working, but no beep.
First open cpu cabinet.
Then refix RAM memory.
Pull cmos cell for 10 minutes so all settings of motherbord are defaults.
Then pull porcessor fan and processor clean dust from all chip and parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistanse.
Thanks.
Sep 21, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
Constant beeping when powered up, no display
If the beeping is constant, check your keyboard for any keys that are stuck in the depressed position.
Jul 07, 2009 | Computers & Internet
My computer
install a new graphics card onto the motherboard into one of the free slots. i prefer radeon cards for durability. if you need more detailed instructions on how to do this please post back! good luck.
Sep 19, 2008 | Computers & Internet
Evga e-GeForce 8600GT, GeForce 8600 GT, Graphic Card Logo
79 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Mike
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
