Question about Kenmore 17459 Free-standing Dishwasher
Blown thermo-fuse twice
I have a kenmore free standing dishwasher has ran fine for 3 yaers but 2 weeks ago blew thermo fuse leaving water in bottom of unit. I pulled front panel found blown thermo fuse and raplaced it. Dishwasher ran fine for 1 week but did same thing last night. dishes appear clean like it ran full cycle but failed before rinse water pumped out. Thermo fuse is blown again, so before putting another new one in and not finding problem I am looking for trouble shooting advice. would partially clogged water drain cause wiring high enough amp draw to blow fuse. As it appears that wash went fine am I correct in thinking problem is in water pump out cycle? When I replace fuse again will there be diagnostic codes in place? Thanks for the help, great site!
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
  • 338 Answers
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
  • 338 Answers
SOURCE: Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
What is wrong with Kenmore Elite 795.75192400?
dear Bill if its a no frost refigerator sounds like you might have to take all the drwars out unscrew or detach the back plate and defrost the fridge manually and then unblock the drain hole which goes to the back of the fridge into a plastick container ontop of the compressor which in turn will evaporate from the heat of the compressor . Hope this does the trick .. good luck. Tony
Dec 01, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bosch lifestyle dishwasher not filling with water. I undid the bottom and it blew out an air block and started. When reconnected again it is doing the same thing
hey can any1 help me I have a bosch automatic, when I turn the unit on the little fan in the bottom keeps spinning and no water enters the unit, iv drained all the water out of the unit cleaned the drain checked to make sure water is getting to the unit then I pulled the panel off the side and held down this red piece like a float valve down and it then fills with water, but its not completing a cycle, any advice what could be wrong?
Apr 09, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Mar 19, 2009 | Kenmore Dishwashers
No power for my Siemans SL84A dishwasher
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
Mar 03, 2009 | Siemens 24 in. SL84A305UC Built-in...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Standing Water in my Dishwasher
hi this is the electric pump thats in your dishwasher. its probably seized up.remove and clean it just might be dirty thanks the appliance doc,
Oct 15, 2008 | Kenmore Dishwashers
Kenmore undercounter dishwasher quiet guard
Presuming that your circuit breaker is not tripped and you have power to the dishwasher, it appears that your thermo fuse is blown. You can replace it for around $20. It comes in a kit form or you can replace the thermo fuse for around $1. The part number is NTE 8096 Thermo Fuse 98 degrees Celsius and solder it in yourself. It is located on the circuit board that contains all the relays and the main computer chip. It clips on and off.
Sep 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Kenmore 17459 Free-standing Dishwasher Logo
76 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
