Question about Mitsubishi VS-55601 55" Rear Projection Television
Model ws65613 green power lite keeps blinking tv does not turn on
  • jason May 11, 2010
    the mitsubishi green blinking light of death usually means replacement of capacitors on the dm board , pwr board and or fmt board
    this model will have bad electrolytic caps on the dm module that will need to be replaced , hopefully not more than those components
    do you need a service manual for your set ?
    can you solder ?
  • 905 Answers
Oh yea don't try to look for a lamp in your tv set that has three crt's!
if you can solder and unsolder , then replace the four(4) 1000uf capacitors on the dm board , and make sure the new caps are 25v or 35v , also check fuses for the two STK 394-250 convergence IC's (ic8c01 , ic8c02 )( on the big heat sink ) , if they are blown then replace the convergence IC's also
here is the service manual that will help in dissasembly and locations of dm board and convergence IC's
http://www.techlore.com/download/24849/Mitsubishi-WS-xxx13-Service-Manual/
Posted on Mar 02, 2009
    Sergeant:
  • 239 Answers
That flashing light either means you ha a power outage and electricity was cut off to the tv. if thats the case the light should stop blinking after a few minutes.
if not the the blinking light is tell you that the projector bulb went out and you need to replace it. order from mitsubishi. really easy for you to replace.
hope this helps.
best of luck.
please remember to rate me.
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
Mitsubishi tv
Check 5A micro fuses F9A04 and F9A05 and if one or both are open replace both convergence IC's part# STK394-250
Aug 29, 2007 | Mitsubishi WS-55859 55" Rear Projection...
The power light on my DS Lite keeps blinking even when its green, and I swear I have never seen that happen before, what does it mean??
A blinking green light usually indicated that your connected to a wifi connection or a ds to ds link.
Mar 07, 2011 | Nintendo DS Lite Console
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
The green light on front of tv keeps flashing and tv wont turn on
Howdy,
The green light blinking indicates your TV has a problem. The problem is that each Brand of TV has different codes and with out the Brand and Model number, I can not help you at this time.
Please, count blinking sequence. Model number will be on back of TV.
Recap : Provide Model Number, Brand and Count Blinks.
First though; unplug TV from power source for 3-5 minutes then plug TV & box back into a/c outlet.
Good Luck, BIG IRISH.
Dec 03, 2009 | Televison & Video
Disney DTD 363-Car 13" tv/dvd
I have xfinity Comcast cable connected to my Disney's CARS TV/DVD combo. I did not have a remote for it because I bought it at yard sale without it. I used Comcast's remote control. I followed their "Searching For Your Code" instructions. #1-turn on your TV. #2-hold SET till red lite blinks twice. #3- enter 9-9-1. The red lite blinks twice. #4-press nd release the CH+ key until TV turns off. #5-once it turns off press SET key nd red lite will blink twice. #6-Now u have locked in ur code. Press power and TV should turn on. Then CH+,CH-,VOL+, and VOL- should work for ur TV.
Apr 16, 2009 | Disney DTD1363-CAR 13" TV/DVD
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Turn tv on green light keeps blinking wont reset
Verify Model # off back of set and mo / yr built......critical for
correct solution....For example, if your # ends with.....13, then
a DM module repair will be needed...replace four capacitors...
1000mf 25v 105 degree.....If different model = different solution
....................................T.
Dec 14, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
364 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
