Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
I HAVE A HOOVER POWERMAX CYCLONIC FILTRATION CLEANING VAC 12AMPS AND I CANT FIGURE OUT HOW TO REPLACE THE BELT AND I LOST THE INSTRUCTION BOOK PLZ HELP
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: manual
Go to hoover.com, scroll down to downloads, enter your model number which is located on the metal tag either on the back or bottom. If it is available you will be able to download it.
Posted on Feb 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Received hoover powermax fusion vac
What is your model number? A Savvy and Powermax are differntent models. The Savvy the handle slides on and there are 4 screws to hold it in place. The Powermax has 2 screws to hold it in place. have you removed them before trying to put the handle on. If you have, you just have to work so it will slide down then put in the screws to secure it.
Posted on Apr 24, 2008
SOURCE: hoover powermax cyclonic filtration system
The hose is clogged. Remove the cover to access the belt and clean out the hose.
Posted on Dec 06, 2008
  • 1214 Answers
SOURCE: I can't seem to find
It's on the Hoover website, I just looked it up.
www.hoover.com F6213900
Let me know if you need anything else.
Posted on Feb 01, 2009
I have lost my instruction book on my hoover Vac;- mosel no U4617-906 is it posable to get a copy SamGlen
http://homeappliance.manualsonline.com/manuals/mfg/hoover/hoover_all_floors_vacuum_product_list.html
Jul 12, 2008 | Hoover Vacuums
The belt is broken on our Hoover Allergen Filtration Model U5018-900 120 v. 60 Hz 12.0 A. Belt 38528040. Where can I get the belt and instructions on how to replace the broken belt?
The owner's manual can be downloaded here (in red, "Download the Instruction Manual (PDF))
http://www.hoover.com/product.aspx?model=U5018900&ds=false
Instructions for replacing the belt are on page 9.
You can order the belt here:
http://www.hoover.com/shop/searchresults.aspx?itemid=221224
Or use the "Retail Locator" on the first site.. Just type in your zip code, and a store that carries Hoover and products near you will be shown.
Oct 07, 2010 | Hoover U5018-900 Bagged Upright Vacuum
How to replace Hoover PowerMAX power nozzle cord?
You can get the new cord at your local vac shop or you can take the power nozzle to the shop and have it repaired
Apr 27, 2017 | Hoover Powermax S3601 Bagged Canister...
HOW TO REPLACE BRUSH BELT ON A HOOVER POWERMAXll VAC. DWSMITH1624@AOL.COM
bottom of vacum theirs clips un latch them it comes off then remove the brush upward then switch belts
Mar 25, 2010 | Hoover Powermax S3601 Bagged Canister...
Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
Mar 04, 2010 | Hoover S3606 Bagged Canister Vacuum
I HAVE LOST MY INSTRUCTION BOOK FOR THE STEAM VAC SPIN AND SCRUB. I WANT TO USE THE STAIR ATTACHMENT, BUT I CAN'T FIGURE OUT HOW TO HOOK IT UP, OR OPERATE IT. I SEE WHERE THE PLUG IN PART GOES IN THE FRONT...
You can download a PDF version of the manual at the link below. I believe you can contact Hoover as well and they might mail you one.
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Good Luck!
Dec 09, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover powermax cyclonic filtration system
Nov 17, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
278 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
