Question about Microsoft Xbox 360 Console
Freezing problems My xbox plays fine from the hard drive, but will freeze up when trying to play the same game from the disc.
  • 463 Answers
Disc is dirty. Lens is dirty. Disc drive going bad.
Posted on Mar 02, 2009
Why is my Xbox 360 S freezing after 20 minutes?
This could be a case of the system over heating in which case you should have items removed from near your console.
You could also try removing the hard drive (make sure your Xbox is turned off before you remove it) and using your xbox without it, if that stops the freezing error then the problem lies in your hard drive.
(How to remove your xbox hard drive: https://www.youtube.com/watch?v=2NhALsgzR0M )
Jul 30, 2017 | The Video Game Consoles & Games
Xbox keeps freezing up
First of all not enough imformation as to what console your talking about but ie if its xbox 360 with hard drive first of all is it just one game or all games if its all games you need to clear the cache you will find imfomation online how to do this for your console make sure your discs are clean ie: No finger prints on them allso if your system as an hard drive try loading the game onto it then play it if by clearing your cache hasnt helped & your discs are clean it may be you disc drive getting tired hope this helps
Nov 19, 2013 | Video Game Consoles & Games
On xbox 360. my gears 3 disc freezes the console. when rebooted it says the disc is unreadable. i'm on my 3rd disc. when i remove the hard drive, i can play gears 3 but cant save . i have played gears...
Hello
Delete any saved game files from your x box hard drive.Unplug x box for 5 min.
Plug back in and power up.
Try game again.
Chances are files have become corrupt.Also delete any files from GOW 1 and 2.
Oct 19, 2011 | Microsoft Xbox 360 Console
Game freezes up on 360xbox
If your game is freezing, it is most likely due to your game being scratched or otherwise damaged. Sometimes, a game can become damaged without you even realizing it. There are two ways to fix this.
1) (Obviously) Buy a new game.
If you don't want to go through the hassle, and would rather just get a fresh copy, go do it. Also, if your hard drive is relatively small or nearly full, I would recommend this.
2) Install the game to your hard drive.
The Xbox 360 has a feature that allows you to install a game to your hard drive. By doing this, the Xbox will run everything from your hard drive, which will make a scratched game no problem. You still need to have the game in the Xbox for it to start, however (anti-piracy measure). Installing is easy. Go to the dashboard, and scroll to where you would normally start the game from. But instead of pressing A to play the game, press Y on it and you should have the option to install it.
Note 1: If you can't install the game fully because it is so badly damaged, borrowing a friends or renting a copy and installing that one will work fine also. As long as you can start the game, you will be fine and freeze-ups will go away.
Note 2: If you have installed the game and it's still freezing, the problem is your hard drive. Some hard drives don't play well with some games, for an odd reason. To test this, try saving and loading the game from a USB flash drive. If it doesn't freeze, just continue to play on the flash drive. You can transfer all of data for the game onto your flash drive from the memory options in system settings.
Apr 09, 2011 | Microsoft Xbox 360 Console
My XBOX 360 is consistently freezing up and won't play
One thing to certainly check, is that the Xbox is broken, not just the game. Try playing all of your games, and keep in mind which ones weren’t working properly. Then, take those over to a friend’s house, and try playing them on his/her console. If they seem to work on one, but not the other, there may well be something faulty about your Xbox.
It is entirely possible that a scratched or dirty disc could be causing all these problems. So what to do about it? Well, the simple thing would be just clean off the disc. Wipe it down with a soft cloth, and give it another try. Another idea would be to rip the game to your Xbox 360’s hard drive. There is more than plenty space on it, and it should play more smoothly from there.
Regards
Aug 11, 2009 | Microsoft Xbox 360 Console
It freezes when i exit the rotunda when my quest update begins that says escort docter li to the extraction piont
YOU'LL WANT TO CLEAN YOUR DISC WELL. YOU MIGHT HAVE A CORUPT FILE YOU MY WANT TO START OVER. BEFORE YOU DO EREASE THE UPDATES AND REUPDATE, INSTRUCTIONS AT YOUTUBE.COM HAPPY GAMING AND HOPE TO SEE YOU IN GEARS OF WAR TWO...
Jul 10, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
My xbox loads games but then it freezes on games that run on a disc
Hi, im not sure but are you playing the games of the xbox 360 Hard Drive?
If orignal discs seem to freeze in the drive then this could be a problem with the disc drive. You may want to get it replaced or if under warrenty get it replaced...
if the problem happens with games that run from your hard drive as well this could be a hardware problem.
Jun 12, 2009 | Microsoft Xbox 360 Console
Game freezes after playing for a while but no red rings appear
Games freeze for two reasons. Overheating and the hard drive locking up. If you have your games installed, you most likely eliminated the overheating problem.
Since you are not getting Red Ring, it probably isn't overheating. That leaves the hard drive. Turn of the console and unplug it. Remove the hard drive. Now is a good time to clean any dust from the connectors or vents. Reattach and play. Some games like Fable 2, Fallout 3, and others are more prone to freezing when accessing the hard drive that others. If it is freezing more times than not, you have an issue with the hard drive.
Jun 09, 2009 | Microsoft Xbox 360 Console
Why does My Xbox 360 Freeze when i play MLB 2K9
If it only freezes on that game, chances are it's the disk that's causing the problems. I've experienced that some xbox games act up if only the slightest scratch is on the disk. If there is, either take it back or pay a few bucks for Best Buy or some video rental place to repair it for ya.
Apr 21, 2009 | Microsoft Xbox 360 Pro System Holiday...
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
