Question about Minolta EP1083 CS/PRO Copier
Minolta Copier EP1083, copies are coming out mostly black
Everything appears to be working correctly, except copies are 95% black. Difficult to read the copied portion.
  • sanders749 Mar 03, 2009
    The counter registers 160,000 copies, tried the above suggestion and also went lighter. The copier has been in a warehouse [unused for 2 years] but worked great prior to storage.
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    Dyou know how old or how many copies are on the drum? Also, how is the exporsure set at? Try making copies with it set to auto "AE"
  • Minolta Expert
  • 1,326 Answers
What you mostly need to do is to clean the optics under the copyboard glass the mirrors are mostly dusty... I would use a soft dry cloth to wipe the mirrors off. There is a mirror under the "Black Box" I would also, use a lightly damp rag with rubbing alcoh. to wipe OFF the scanning lamp & reflector. Cleaning the optics should get read of the dark back ground, but the drums are only good for 80k... You may need a new OPC drum & blade. Good Luck
Posted on Mar 04, 2009
Why is xerox 1255 page full of dark smears?
May be exproser lamp broken or damage .Please check the lamp .its no on than copy black
Jun 14, 2014 | Minolta EP1083 CS/PRO Copier
I have a Minolta CSPRO EP1083, it stopped making copies, the paper comes out blank. I put a new toner bottle in and the paper still comes out blank.
Problem on lower charger.Some times wire was broken .It has 2 wire one saparation wire and other high voltage wire may any one broken.Assemble new wire may be it fix problem.Other lower charger was damaged ,need new one .If you try clean all socket and dry.I hope your copier good working.
Aug 02, 2011 | Minolta EP1083 CS/PRO Copier
My minolta 1083 is making black copies ,The drum is cover with toner .I can clean the drum off,& make 2 copy then it`s cover with toner again making black copys
you need to clean out the drum unit of waste toner than probably have to replace the cleaner blade.
Also check to see if there is a tension spring employed to add friction(since this is a phase - out model, I'm guessing there is), you might have to modify this spring to add tension to the cleaning blade support plate.
Feb 23, 2011 | Minolta EP1083 CS/PRO Copier
When you run the code appears CO5, and then after 3 seconds does not operate copy machine
Check and replace the thermal fuse, located within the fusing unit, under the top cover and where the paper exits the machine.
Jan 02, 2011 | Minolta EP1083 CS/PRO Copier
The phocotopy copy brings out a black background which was not on the original copy
if your original that you are copying is not white paper you will get this issue also another problem is that your optics mirros may need cleaning in general the machine will require a general service by a certified engineer this will fix your issue
Nov 11, 2010 | Minolta EP1083 CS/PRO Copier
MINOLTA CSPRO EP1083 PHOTOCOPIER NOT WORKING DISPLAYS "COF 30 " AND STOPS COPYING
Open the paper drawer and switch the green button which is located towards the back of the paper drawer on your left. My copier does this everytime I add paper.
Oct 11, 2010 | Minolta EP1083 CS/PRO Copier
I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
Jan 19, 2010 | Minolta EP1083 CS/PRO Copier
Minolta Copy Machine
hello sir; You need to replace drum cleaning blade or drum cartridge will be take care of your problem.
Jan 29, 2009 | Minolta EP1083 CS/PRO Copier
Copier only copies 90% of sheet in 100% mode
you have to go to service mode to adjust it that's ,technician's job,better looking for a local service provider
Dec 09, 2008 | Minolta EP1083 CS/PRO Copier
Minolta ep1083
sound like somthing in the developer unit take out and see if developer is even across mag roller.
make sure t/s charge unit are clean
hope that help you
Oct 22, 2008 | Minolta EP1083 CS/PRO Copier
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
