Question about Poulan Pro Chain Saw 46cc 20"
Cannot reassemble trigger for remington yardman
There are 2 separate "wires" that somehow hook throttle body to trigger?????
  • John McKinney May 11, 2010
    i'm going to need a little more info to help you on this one. need all of the numbers you can get me on your saw. (model, serial, etc.) then i will be able to walk you through it or get you a diagram to help. thanks.
    President:
  • 2,220 Answers
Clarification Request
Posted by mckinney3232 on Mar 15, 2009
You must help us if we are to help you.
Posted on Sep 15, 2009
How to operate trigger lock on an early EL-1 Ser# 001191 Remington Limb N Trim electric saw.
This is location of manual on line. see figure 10, page 8: http://lawnandgarden.manualsonline.com/manuals/mfg/remington/099039j_2.html?p=8
Sep 10, 2014 | Garden
1988 chevy k 1500 where is the trottle positionnig sensor
its on your throttle body under the big black plastic where your air filter hooks up 2. and your throttle cable hooks there too. wires plug in2 it.
Oct 10, 2012 | 1998 Chevrolet K1500
I broke the throttle trigger on a 445 Husqvarna chainsaw. I removed all of the screws etc from the orange handle bar. I am still unable to separate the two orange pieces. I do not want to force and...
The two halfs of the rear handle do not seperate, once you have removed the r/h side grip you can remove the throttle lock, you then need to remove the pivot pin from the trigger with a pin punch, the trigger can then be pulled down and out, you may need to disconnect the throttle wire from the carb if you cannot drop the trigger far enough to remove the wire from it.
Jul 02, 2011 | Husqvarna 16" 457cc Prosumer Chain Saw ...
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and...
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Jul 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Throttle linkage
It seems that Mac engineers could have come up with something better than the M.M. kluge that they did. The problem is hooking the wire link to the plastic hook on the trigger plastic casting while juggling the front case and engine body. It appears that it should just snap together, but knowing how plastics get with age, it would appear that the trigger should be replaced every time the case comes off. I had trouble with mine and wound up straightening out the wire link end somewhat to force the parts together--it continues to work though. Hope this helps!
May 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
Mar 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Motor removal
The body on this unit split apart at the bumpers. You will open the front lid and slide the bumpers and the internal slides forward to separate the panels then the rear housing will drop off. At that point you must gently separate the halves by opening back to front. Pay attention the the hinge area for the bag chamber door as there.are 3 tabs which will lock together during reassembly. Note how each component slides into a body channel for positioning for reassembling
Do not yank apart, look inside to where the tubes and wiring harness are located and disengage the bag lockout switch from the bag cage if equiped, being carful not to lose the spring.
The wiring harness in this unit is designed so the longest wires reach the furthest terminal, but you should mark each lead in the body and also in the motor shroud
**** Also note the position of the thermal couple on the motor as you remove it***. The motor and rewind will separate form the bag cage by lifting up and back with the vac laying upside down. Then gently separate the shroud from the rewind where they are clipped by prying with a flat screwdriver. Reassemble in reverse order tucking the cord grommet into the body, then closing from the hinge area back.
Best of luck. Let me know if you need more help.
Oct 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
POULAN TRIGGER PROBLEM
Remove the air cleaner which usually exposes the carburetor--operate the throttle (engine off) and watch what moves--likely wood chips blocking the action--less likely, a wire linkage got bent somehow, or there is sawdust in the trigger mechanism. From your description, this saw starts full-throttle at the get-go. Sort of dangerous!
Jan 19, 2009 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
