Programs and temperature
None of programs running propley only b and temperature is very hot
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Sep 14, 2010
2003 dodge ram 1500......no heat
Does your heater motor run when you turn speed dial ? Have you checked the two hoses that run from the engine compartment to the heater core ? When car is at operating temperature, carefully touch both hoses which should be warm or hot. If only one if hot, then you may have a bad actuator. If both are hot, you may have a clogged heater core or none functioning heater motor. or resister.
If motor is not working, check fuses, if good, then check for power at the switch and then at the heater motor.
Dec 17, 2016 | 2003 Dodge Ram Pickup 1500
It dont work on lenovo
There are many reasons y0our laptop is running slow.
1. Make sure the ventilation holes of the laptop are not blocked with dirt, or blocked by placing laptop on your lap, or a non-hard surface. When the CPU gets hot, it will throttle down to run slower. You can install a temperature monitoring program to determine if the CPU is running too hot. 2. If the temperature is within normal range, then check to see the amount of free space on your HDD. Keep at least 10% or more free. 3. If that is ok, then you may not have enough ram to run all the programs. Windows 7, or 8 should have at least 4GB or more RAM. 4. If that is ok too, then you may have a lot of unnecessary programs running. Run a virus scanner program to get rid of viruses, etc. 5. Uninstall unused programs. Sort by date to see which programs were installed most recently, By doing this if you can remember when you started having problems, you can uninstall programs installed around that time that may be causing your problems. As you can see a lot of things can cause slowness. Good luck!
Mar 31, 2015 | Lenovo IdeaPad Computers & Internet
Beko sensordry 6kg gets hot on sensordry programs but won,t get hot on timed programs and keeps stopping and starting, any ideas please?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!!
Feb 13, 2015 | Dryers
Eax300se problems with XP
First, open your Task manager and open the "performance tab". There are a lot of built in programs in XP that can peg the CPU to full and this will slow/crash your computer. If any program is eating 100% of your CPU power for a long time, use Google to see how to fix the problem.
Test your RAM: Open the Start Menu and type in mdsched.exe, then press enter. - Then follow the procedure you think is best for your machine.
If your machine is capable via the BIOS, check to see at what temperature the CPU is running. Some processors run hot all the time, but some processors can't take the heat and will crash.
Also, if your computer is not under warranty physically check to see that the CPU fan is moving freely... and the GPU fan as well if your computer has one. Clean any dust and what not off of the blades if it is dirty, or replace if necessary.
If none of that seems to be the issue, remember that XP is considered "End of Life" and a lot of programs will not run on XP any more. Also remember that while some programs might still work, they may still be buggy on XP.
Oct 16, 2013 | Computers & Internet
How hot should my onboard CPU temp. Run at and when is it to hot
40-49 degrees celcius (104-120F) is normal temperature for most systems. It is not uncommon to see higher temps when doing process intensive programs such as video games or encoding.
Sep 19, 2011 | Dell Computers & Internet
The heater just quit working. It worked fine yesterday but this morning it does not. The car is running a little hotter trhan normal but not overheating. Any ideas?
I would check to make sure the radiator is full and the overflow tank is filled to the proper level. It doesn't have to be very low for these cars to stop blowing heat.
Feb 01, 2011 | 1992 Subaru Legacy
Carburetor problem wont run propley.how do i fix
If you don't spray the rubber parts, you can use carb cleaner. With a bike that old, carb kits would be a great idea though. Try and put an inline fuel filter in there as well as it will help keep the carbs cleaner.
Jul 11, 2009 | Yamaha FZ 750 AE (U.S Motorcycles
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
