Question about Brother MFC-9440CN Laser Printer
Brother Printer HL-4040CN error reads Print Unable 3A ... turn off and on. This does not fix it, any suggestions please
  • Anonymous Mar 16, 2009
    same problem. clean printer, brand new. gives me red screen and same message. trying to fix for a whole day. this is ********* ! for a brand new expensive machine !
SOURCE: Brother HL-4040CN won't read or show new refilled cartridge in the LCD
Q: Brother printer toner refill.?
A: yes and no. it is easy to fill the toner but if it is the original toner which came with the printer, they deliberately leave out a $4 starter gear which is needed to regulate the amount of charge going to the drum. Without this gear, the copies will come out too light and be nearly useless. I threw out two of these printers until I came across Northbay Toner who explained this to me and provided what I needed. I now have two Brother lasers working well on $5 refills. For more info, see http://ccs-digital.com/northbay.html
Posted on Jul 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Brother HL-4040 Laser Printer -- Print Unable 6A Error
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
RVdave
SOURCE: Printing envelopes on HL4040CN
I just bought a HL-4040CN and all my envelopes wrinkled, regardless of the size, paper thickness or software settings (thin envelope, thick envelope, etc.). Here's how I solved the problem....Open the rear panel and you'll notice a small gray lever on each side, which is probably pointing to "A" on the scale (A, B, Envelope). Move both levers to "Envelope" and close the back panel. The troubleshooting manual says the levers should be moved back to "A" after printing the envelopes, but I left them in the Envelope position and can't see any difference when printing regular or test pages or envelopes, except the envelopes are no longer wrinkled. I called Brother and asked them if there was any reason why the levers can't stay in the Envelope position, and they told me they could be left there if it wasn't negatively affecting other documents. Now, I have a great printer that prints everything without any problems. Hope this helps.
Posted on Feb 09, 2009
bschilz
  • 2049 Answers
SOURCE: Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Posted on Sep 17, 2009
SOURCE: how do you reset fuser life on a brother HL 4040cn
Press the Go and 'Up' buttons at the same time in the ready status.
The "Reset Parts Life" will appear on the LCD. Select the applicable periodical replacement part by pressing the 'Up' or 'Down' button and press the 'OK' button.
Posted on Apr 08, 2011
Print unable 32
This is not just a density sensor, this is a plastic cover over it that is getting stuck. There is a piece of soft rubber attached to the solenoid that is getting very sticky over time. Removing this rubber and stretching solenoid return spring corrects the issue. Search web for the service manual and follow chapter 8 to disassemble the printer correctly - takes less than 10 minutes to do it
Aug 29, 2011 | Brother HL-4040CN Laser Printer
Is there a setting on the Brother HL-4040CN for black print only?
When you try printing any file or document, a printing properties option appears.
In this option, you have choice to print only with black colour.
Jul 12, 2011 | Brother HL-4040CN Laser Printer
Brother 4040CN
This message will appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one
May 21, 2010 | Brother HL-4040CN Laser Printer
Print Unable 20
Bad news. The laser diode responsible for printing black has up and died. You need a new Laser Unit, part number LR1461001. Brother has released a "Service Update" about this one; the instructions for replacing the laser unit run to nine pages. If you're within the 1-year warranty, it won't cost you, but it won't be printing with it today.
Jun 11, 2009 | Brother HL-4040CN Laser Printer
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will...
i have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
Jan 28, 2009 | Brother HL-4040CN Laser Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Brother HL-404CN color laser priter unable to print error message E1.
I have a Brother HL 4040Cn printer that has stopped working completely with the exception of the side exhaust fan running. This machine has printed low volume of work over it's 18 month period and I have read another post today describing the same problem!! Any ideas? Brother want a minimum of €150 to take a look at it.
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother MFC-9440CN Laser Printer Logo
364 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
