There is no sound coming in my computer
Motherboard sound card
    Sergeant:
  • 239 Answers
You can go to the website of the motherboard manufacturer and download the drivers for the sound for free.
best of luck.
hope this helps.
please remember to rate me.
Posted on Mar 02, 2009
I have an hp laptop.but the sound is given me problems actualy the sound is coming out.
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question or exclamation mark? ! or a red X Right click to install drivers if you dont have a motherboard disc you will have to download the drivers
what sort of problems if the sound is coming out static noise?.....
you might have to clean the dust from around your sound card and the socket its in
hope this helps
Aug 12, 2011 | HP Computers & Internet
How to use speaker in computer?
Does your motherboard has an onboard sound card? If it has then read your motherboard manual especially the audio section of the manual where the topic is described how and where to plug in which audio jacks coming out from you speakers (speaker system) to which part of the external audio ports usually located at the rear end of your computer case. You need to install the sound card drivers to activate audio properties of your computer of course, to actually use the speakers.
You can also use the front panel audio port of your computer case where you can connect your speakers to as well.
In case your motherboard did not come up with sound card installed you can always install an external sound card and then connect the speakers to the proper external audio ports of the card. Just read your motherboard or sound card manual. It is all there.
Jun 03, 2011 | Audio Players & Recorders
My New sound card did work, but i had to Format my comp.
CAREFULLY remove your sound card and then try to boot up.
if it does not boot up then your computer has a problem and you need to consult your MFG.
if it does boot up then check the specks on the sound card and check if it is compatable.
if it is compatable, make shure that the contacts are clean (use a compressed air cleaner), and that the sound card is not damaged, then reconect (with the computer off).
______________________________________________________
In the way of only one speaker working, you probably have a loose connection; bad cable; or a bad speaker.
Aug 18, 2009 | Pine Technology XFX Mach4 KT400ALH...
I can't hear the sound after formatting the computer
Hi dear,
1- You have formated the the hard disc and install OS again.
Therefore
you have to install AUDIO (sound) driver.
you can use audio driver disk or motherboard disk which was come with motherboard.
or you can install sound driver from the internet.
Thanks
Veeru
May 07, 2009 | Compaq Audio card Sound Card
Sound problem
check in which sound card the speakers cable is pluged...is it in that sound card for which the drivers are installed?
Apr 29, 2009 | Foxconn 6627MA-RS2H Motherboard
Sound
http://www.foxconnchannel.com/support/downloads.aspx
Copy paste the above into address bar this will take you to a site for foxxcon drivers you will have to enter your computer details yourself as I do not have them
Jul 13, 2008 | Computers & Internet
Foxconn sound card drivers
same problem
I formatted my hard drive and reinstall windows xp but no sound comes from speakers I tried to install audio drivers from the motherboard CD "foxconn" but PCI driver can not be installed what should i do?
Apr 07, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Alarm sound coming from hard drive
I'm assuming the alarm sound would be coming from your computer tower...in this case, what does the alarm sound like?  1 long, 2 short?
It sounds to me like your video card failed on you.  I assume you're posting here because your computer has this specific motherboard.  If you're comfortable opening your computer, you may want to make sure that your video card is set properly in its slot.  It will be in the brown component slot above all the white component slots.  Try to gently push it in first.  To really make sure it's seated properly, take the card out & put it back in.  If you're not sure how to do it or you're not comfortable doing it, then leave it alone.  Chances could also be that your video card is good, but something failed(slot, circuit, etc.) on the motherboard.
Another possibility is a bad setting in BIOS, which can cause errors.  In this case, you'd have to reset it, which also requires opening your computer.
Do you remember what you were doing on the computer before this happened?
Oct 26, 2007 | ASUS P4P800E Deluxe (90M8LCW0G0EAY)...
Computers & Internet Logo
462 people viewed this question
David Payne
David Payne
