Question about Samsung LN-S3238D 32 in. LCD HDTV
When I turned the tv on only vertical lines appeared
My tv had been working perfectly fine. Turned it on last night and colored vertical lines appeared on the entire screen and no picture. My tv is a Samsung Model LN-S3238D Lcd and is approx. 2 years old.
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Black 3" vertical line through the center of my Plasma TV
Sounds to me like one of the drivers for the display died. Typically this requires a replacement of the entire panel (expensive) but I'd check with your local repair shop
May 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Bad picture on Toshiba
this is a malfunction vertical deflection block of your TV-set .please contact the nearest repair shop.do not turn it on until then,please.
Apr 17, 2008 | Toshiba 36A40 36" TV
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Sep 11, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung LN-S3238D 32 in. LCD HDTV Logo
1,068 people viewed this question
Henry  Thomas
Henry Thomas
