Display F-05' 'Display F-05' Machine won't drain water out
  • Rob
    Rob May 11, 2010
    Make and Model of said machine?
  • 15,935 Answers
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
I have a Bosch she4ap06uc/05 quick wash light flashes. I have tried to reset it and it will not reset. The sump pump work and drains all the water out of the machine. It turns off and on fine but when...
Bosch she4ap06uc/05 This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Nov 13, 2011 | Dishwashers
My machine is showing a message f 05 pls help
Hi.
F-05 indicates a draining problem. Disconnect power. Move the machine forward. Check the hose at the back of the machine. Try running a cycle with drain hose down in a bucket.
Check also the drain pump filter, most Hotpoint front loaders have the access door in front at the bottom. Open drain filter door, undo drain cap, collect water using a container. Disconnect power before starting.
Aug 06, 2011 | Hotpoint Washing Machines
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Machineflashinf f-05
If not :
Mar 09, 2009 | Hotpoint Ultima WD72 Front Load...
My Hotpoint Aqualtis washing machine keeps getting stuck towards the end of its cycle. It shows a F-05 on the digital display. Previously I was able to get the washing machine to finish by putting it on...
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Jul 08, 2008 | Washing Machines
F-05 error code Hotpoint WT746
how do i fix error f-05 on my washing machine
Apr 02, 2008 | Washing Machines
HOTPOINT WT940P
Lower the outlet hose into a low bowl, if water flows then you need a new pump cost around 20 pound to buy, If no water comes out the you have a blockage somewhere.
Nov 29, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Help anyone. Machine will only start for the first minute
F/05 Water Temperature Sensor Error If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed. Check the Water Temperature Sensor, Heating Element and Element Relay Check connections to the Sensor, Heating Element and Relay Hope this is helpful.
Sep 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
