Question about Motorola Cell Phones
Motorazr ve20 is the type of phone i have. I recently bought a micro sandisk sd reader to download music. I was able to put the music on the memory card but when i put the memory card in my phone it says its not supported ''so how can it fix it?''
You will need to format the sd card with the phone, you can find this info in the manual. once that is done put the songs in the my music folder, now this is the improtant part,do not put aditional folders in this folder or the phone will say it is unsupported misic files. they must be placed in individualy in order to work properly.
Posted on Mar 25, 2009
    Problem Solver:
  • 8 Answers
It depends on the type of files you are putting on the card. MP3 format is the best for music on your phone. G/L
Posted on Mar 02, 2009
How do i download music fRom my computer onto a SanDisk with a micro in my cell phone
hi what you will need to do is either use a USB cable from your pc to your cell phone, the memory stick (micro sd) will show as a removable device then just copy and past the mp3 files that you want to copy, the other way is to buy a sandisc micro card adapter, this looks just like a normal SD card, but at the top of it there is a slot that you put the micro SD card in then put it in a card reader as normal, then transfer the music over to that disc, when done just pull your micro sd card from the adapter and insert it into your cell phone as normal and away you go...hope this helps
Aug 18, 2010 | SanDisk Computers & Internet
I have a music kit for my Motorazr VE20 (alltel) yes Alltel should be Verizon but one still does exist. Anyways the music is on my computer but my phone just doesn't seem to "sync" up with it. Which in...
ok the music kit had virtually no instruction and was tricky main thing is you cannot hook up the phone and cable to the computer first or together first thing run the disc or download the software from the link listed in the booklet then plug in your cable no phone and reboot to detect the plug and play device it will run its own drivers just hit yes to everything and let the wizard install it then plug in your phone and it will run its own separate drivers again hit yes let it run and then it will be able to sync when you press sync it will pull all of your music to a file remember this location write it down or you will be lost if you unhook it whille its transferring or want to use it later then drag and click the music from your media player over to the music kit software it will transfer it over for you its alot i know im sorry let meknow if you have trouble i was an alltel customer serivce rep for three years ill do my best by memory to help you out since I was recently laid off from verizon downsizing the alltel call centers
May 21, 2010 | Motorola Mobility MOTORAZR VE20 Cell Phone
I have a sd micro card and i want to load music on it from my computer to put on my phone
This is a relatively easy problem.
You can do so by using a memory card reader.
You can easily get a memory card reader from any local store at a cheap price, depending on your country.
Most of the Memory card readers come in USB type, so what you just need to do is to plug it in any available usb port on your PC, and then insert your
sd micro card in the appropriate port for it.
For SD Micro Cards (The Smallest Types), most times you might need to first insert it in a Small Card Adapter that comes with SD Micro cards, before inserting it in your USB Card Reader.
Hope this helps you out.
Kindly let me know how it goes.
Good luck.
Nov 19, 2009 | SanDisk 1GB microSD Memory Card
MicroSD does not contain supported music files
1. Install the sd into the phone.
2. Go to Menu > Settings > USB > Mass Storage
3. Connect the MotoVE240 to your PC via USB
4. Under My Computer open drive (E:).
5. Find the folder that has your music in it. Example: My compter made a folder called Music.
6. Drag music from that folder to the my_music folder. (the phone will only read music that is in this folder.)
7. remove your phone from the usb
8. press the music note on your phone and enjoy your music
Jul 13, 2009 | Motorola Cell Phones
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
May 30, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Micro SD card wont work
Try Formating the 1gig chip in 'Fat' not Fat32, then put it back in phone,, should work then.
Also the phone aparently will only recocnize up to 2Gig (But U need a Firmware upgrade)
Hope That helps!
May 23, 2009 | Palm Treo 750 Smartphone
Having problems playing music frommy sandisk 4gb micro memory card on my motorola ve240 cell phone
I have a similar problem, the issue for me was windows media player was creating a folder called music on my sd card and uploading the music there during sync function. However, the phone only looks in the \my_music folder on the SD card. Sync your phone, then rename the newly created music folder to my_music and the player will work. Still looking for a permanent solution to this problem.
Apr 27, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
Need help
you need to install memory card in phone then attach a data cable specfically for your phone (available at cell phone dealer) into phone and the other end to the usb of the pc if our phone came with software load it on pc then use the software to transfer the music files from your pc to your phone.
Jan 09, 2008 | Electronics - Others
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Nov 01, 2007 | LG CU500 Cellular Phone
Cell Phones Logo
128 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
