Question about Universal Remote Control Dish Network IR/PVR Remote
How to take apart a dish network remote control. i pulled the battery cover off and took the screw out but it's still not coming apart, i may not be putting enough force on it, but i don't want to use to much and break it.
Sounds similar to the remote that came with my dish network vip-722. It took a bit of force to mine apart. There are tiny tabs along the side of the remote. I was able to force them up with a flat head screw driver.
Posted on Apr 05, 2009
How do I change batteries?
To whom it may concern,
Remove the back panel on the remote, remove the dead batteries and install new ones in the same orientation that you found the previous ones in. Your remote is now ready to go.
Best of luck
Dish guy
Mar 15, 2015 | DISH Network IR Remote Control
I cant find the code to my philips univ ersal remote control
it should be inside the remote, you'll need a phillip head screw driver, to pull it apart. Lift the back of the remote battery cover off to find the screw.
May 03, 2011 | Philips Televison & Video
Took apart remote and little white tab fell off. how do i reposition it
artisyicnell,
Are you still having problems with your remote? If so, there is a tab at the bottom of the remote that send a signal to the receiver box. This tab slides in at the bottom of the remote. Removing the battery cover will give you access to the area where the tab snaps in. I hope this helps.
Ray Calo
DISH Network - Executive Offices
Oct 23, 2010 | DISH Network 721 DVR Remote Control
My UHF por controller is not running my secondary tv.
davidauriti
If none of the lights light up on the top of the remote when you press/release Select, check to make sure the batteries are placed correctly in the remote. If they are, you may need to readdress the remote to the receiver. I have provided instructions on how to program the remote to your receiver. I hope this helps.
Program remote, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Jul 11, 2010 | DISH Network 142923 Remote Control
DISH Network UHF/IR Remote Control: switch 21.0 remote from uhf to ir...
There is a key in the bottom that has number 2 on it . Turn the key over to number1 and slide the button under the battery cover if needed from a to b or vise versa
May 18, 2010 | Universal Remote Control DISH Network...
How to open dish network remote control made by echostar
You are better off getting a new remote sent to you.
Thanks for using Fix Ya.
Feb 08, 2010 | DISH Network 301 DTV Receiver
Not working. Lights don't come on. Have replaced
This is usually a defective remote and will usually drain new batteries in days. Have a replacement sent to you by Dish. Thanks for using Fix Ya.
Jul 21, 2009 | DISH Network IR Remote Control
I can only use my channel up and down buttons to navigate on my remote control. Why can't I just press 2 or 50 instead of going thru 2-001, 5-001, 002, 003, 7-001, 02 etc to get from 2 to 50?
Take the remote control apart, batteries out, pop apart, (any screws? - remove them.) Clean the rubber contact pad with mild dish soap and water, pat dry. Clean the circuit board with a soft towel and windex or equivalent. Clean the push button holes in the top cover with q-tips and windex. Reassemble, batteries back in. Test...Does this help?
Jul 05, 2009 | Sansui DTV1900 TV
DISH Remote burning through batteries!!
most likely there is a button on the remote that is stuck on. try moving all the buttons to see if they "feel" stuck. if not then take the remote apart and clean the contact pad bottoms and the surface of the board with rubbing alchohol. good luck!
Feb 15, 2009 | DISH Network IR Remote Control
Universal Remote Control Dish Network IR/PVR Remote Logo
4,237 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
