Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
WAND WILL NOT PICK UP - NO SUCTION POWER. CHECKED
WAND WILL NOT PICK UP - NO SUCTION POWER. CHECKED HOSE AND UTUBE AND BOTH ARE CLEAR. NEED TO REMOVE FILTER TO SEE IF NECESSARY TO WASH; HOWEVER, CANNOT REMEMBER HOW TO DO SO AND NO LONGER HAVE MANUAL.
hancockbarb@yahoo.com
  • 328 Answers
Check out: http://www.dyson.co.uk/support/help.asp?model=SUP-DC14&article=527  and pick the suitable model that matches yours.
Posted on Mar 07, 2009
Suction tranfer
Hi there, it's Jack at Dyson.
DC24 includes a changeover valve which diverts suction power from the main cleaner head to the wand and hose, when you remove the wand from the vacuum.
If your machine doesn't seem to be diverting the suction correctly, we'd recommend checking for any obstructions in the ducts and at the base of the hose. Our online Support guide should help: http://www.dyson.co.uk/support/dc24new/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usualdc24/check-the-wand-and-hosedc24
If you'd like further advice from our experts after giving this a try, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 25, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Wertheim x3000 motor running but little suction?
Check all of the filters. When there's extra heat, it's usually blocked filters.
If not, dismantle the wand and use long pipe cleaners or a bottle brush to clear any possible jams in the wand or head. Remove the hose from the main unit and if possible, drop ball bearings or marbles down the hose to try and clear any blockage. Remember to recover all of the ball bearings or marbles before you reassemble the hose and wand.
Aug 13, 2014 | Vacuums
It does not have the suction to pick up like it did.
Check hose, wands, power nozzle for blockages.
There is a screen located at the bottom of the bag well. Make sure this is clear of debris.
There is a possibility the motor is wearing out and needs replaced.
Feb 07, 2011 | Electrolux C101 Bagged Canister Vacuum
I think the power head is clogged with pine needles. The carpet head is not picking up. How do I open it to clean it out?
Make sure you have suction at the end of the hose. If not, the clog is most likely in the hose. Detach hose from vacuum and wand. Drop a coin into one end and allow it to fall through. If it doesn't drop out, the clog is definitely in the hose. Then visually check the wands for a clog
Disassembling the power nozzle is not necessary, or recommended. First, ensure the clog is in the power nozzle. Drop a coin in the wand end and see if it falls out. If not, the clog is elsewhere. You should be able to clear the power nozzle by disconnecting the wand. Use the handle of a table knife to try to push the clog back through the power nozzle, toward the brush. If that doesn't work, try using long nosed pliers to clear the clog.
Jan 04, 2011 | Rainbow 75th Anniversary Canister Vacuum
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant...
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
May 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not picking up dirt. hardly no suction
if your model has a hose for a wand or brush attachment then remove the hose and check it for clogs.
Jan 23, 2010 | Oreck XL Ultra Bagged Upright Vacuum
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
250 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
