Question about Goodman GMS90703BXA Heater
Runs on emergency mode
Goodman runs on emergency and my bill has skyrocked
    Novelist:
  • 189 Answers
By emergency mode I am assuming that you have a heat pump connected to the furnace. If so your heat pump is not functioning properly. For this I recommend a service man. To many possible problems in a heat pump to diagnos over the computer
Posted on Mar 08, 2009
Is there any danger in running my Carrier HVAC in "Emergency Heat" mode all the time?
No theirs no danger in running the Emergency Heat all the time, Emergency Heat is your backup heat mode. when the Heat Pump is not working do to a malfunction or Defrost, the Emergency Heat kicks in. The Emergency Heat is usually electric heaters so your electric bill will be much higher.
Nov 07, 2016 | Carrier Heating & Cooling
How to unlock my phone it is in emergency mode
call your service provider they do things like that when people do not pay their bill
Mar 29, 2015 | LG Cell Phones
I have a Huawei straight talk phone and it's saying emergency calls only. Why would it say that? I have plenty of minutes just all of a sudden today it went to emergency calls.
Did you run out of service days? Because, if you don't pay your bill to your phone by the "Due Date", it will shut off your services, including messaging, phone calls, but not emergency calls. But, if you did pay your bill, then I don't know why it would be doing this, other than your in airplane mode.
Jul 30, 2014 | Huawei Ascend Y Smartphone - Straight Talk...
I JUST BOUGHT THIS UNIT IT HAS THE OUTSIDE UNIT AND THE INSIDE UNIT AND I WAS TOLD THAT THE HEAT PACKS IN THE INSIDE HANDLER IS FOR EMERGENCY HEAT ONLY...IS THIS TRUE?
Yes, if you are talking about a heat pump. It you have an electric furnace inside, the electric elements are for emergency heat. Otherwise, unless you switch it manually at the thermostat, the heatpump (outdoor unit) will run all year around. If you want to use your inside heater (electric heater) just switch your thermostat to "emergency heat" and it will turn on the electrical elements instead of the outdoor unit. This way will make your elec. bill higher tho. The heat pump is much more efficient. Hope this helps you , have good day
Jul 21, 2011 | Goodman Heating & Cooling
I have an issue with my goodman splitt system. It is a 2 ton unit. 2 days ago the heat would come on and when the temp came up to my setting the heat kicked off, but the blower kept running. it does not...
what is the fan setting at? If its set to on then it will rum all the time if its set to auto then it should only run in heating or cooling mode? It is located on your tstat
Dec 30, 2010 | Goodman Heating & Cooling
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Sometimes the auxilary heat light comes on, and this morning the auxilary and emergency lights were on. Our electric bill has been really high the past two months.
Assuming we are talking about a Heat Pump system with an outdoor condensing unit and an indoor air handler, it is not uncommon for electric bills to escalate during the harder winter months.
Typically, the auxilary heat light energizes whenever the electric strip heaters are in use. These heaters are used to supplement the heat from your heat pump system which will be unable to maintain desired occupied setpoint with outdoor temperatures below 35degF. At outdoor temperatures below 35degF is not uncommon for the heat pump to run non-stop and the electric heaters will cycle on and off as the temp in the house drops between 1/2 to 1 1/2degF below setpoint. The electric heaters will also come on when the system goes into a defrost mode...defrost modes typically last anywhere between 2 - 8 minutes. The emergency lights, depending on your thermostat, will come on whenever the thermostat is placed in EMER HT. Some systems energize the emergency heat lights to indicate there is a problem with your condensor unit.
I suggest you ensure the thermostat is in HEAT mode and not EMER HT mode. Also, while the system is running, step outside and visually inspect your condensing unit. Is it running? Does it appear and sound like it is running normally?
Don't forget your air filter. This is the single most important and most-neglected maintenance item on your system.
If after these steps, you still feel as though you are having problems and would like to try and correct them yourself, please let us know.
I hope you find this information helpful. Good Luck to you! :-)
Feb 26, 2010 | Weather King Heating & Cooling
Goodman Heat Pump E.Heat mode kicks in by itself (unit in A/C).
you have a white and yellow crossed up in the low voltage circuit
Jan 24, 2010 | Goodman CLQ36AR49 Air Conditioner
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman GMS90703BXA Heater Logo
331 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
