Question about HP Photosmart C3180 All-In-One InkJet Printer
New Laptop not Reading or printing,
I think its the Vista and its not compatible. Is there any way we can change this? Thx!
  • 408 Answers
Go to hp's website and check for vista drivers.  If there are none listed, you may be outta luck.
Posted on Mar 02, 2009
I cannot get my laptop with vista 64 to access the print server. is there a fix for this?
Most older printers are not compatible with the new VISTA program. I have a $350 printer which can not be used although a cheap $30 printer that is 8 years old will work with VISTA. I was glad I save the old one
Jun 25, 2010 | Linksys Wireless-G WPS54G Print Server
May i change my laptop acer aspire 5680 WLMi with window 7
Sure, because your laptop configuration complete the minimum requirement for windows vista or
If we are unsure of an application compatibility with Windows 7, the following Microsoft link provides searching capability to identify if a specific application / device will work with Windows 7 or not:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
thanks and best of luck.
Oct 26, 2009 | Acer Aspire 5610-4648 Notebook
Compatibility of HP Deskjet 3320 printer with Vista?
1st you remember your previous OS is Vista or others. Then You will installed this Printer in your compatible Opearating System.
Thanks
Aug 12, 2009 | Computers & Internet
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Unable to use Memory Card with PC VISTA
The scanning software for your printer must be installed separately from the printer software on Vista systems. The following link will take you to the page to download the scanning software....just find your model number and select it:
http://www.epson.ca/cgi-bin/ceStore/support/supAdvice.jsp?BV_UseBVCookie=yes&noteoid=86150&type=highlights
May 03, 2009 | Office Equipment & Supplies
Umax astraslim se scanner
my scnner not cannect the computer
Sep 18, 2008 | Umax Astra 2200 Flatbed Scanner
Can't connect wirless to the printer I
Hi Judi,
I'm not sure but if I remember correctly the Hp F380 is a 3 in 1. I have used similar models. But did you install something like this
Miscellaneous Accessories s.gif s.gif q6259a_70x100.jpg HP Wireless Printing Upgrade Kit Q6259A s.gif Product name HP Wireless Printing Upgrade Kit s.gif Compatibility: View complete compatibility list
Apr 06, 2008 | HP DeskJet F380 All-In-One Printer
Not compatible with windows vista
that is true officejet t45 is not supported by vista
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808542&lc=en&cc=us&dlc=en&product=60398&lang=en
Jan 25, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
HP Photosmart C3180 All-In-One InkJet Printer Logo
19 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
