Question about Toshiba 43HX71 43" Rear Projection Television
My TV is showing a double picture
My toshiba 43xh71 color TV is doing what one of my freinds describes as ghosting. The picture any sub titles and the TV guide are distorted and showing as doubles. I calleed a repair service and they said to unplug it for 25 seconds but that didn't work.
  • Sugar55 Mar 04, 2009
    Hi Dan
    Thank you for your quick reply it may be a convergence problem as you suggested but I'm not comfortable with soldering or putting any kind of heat on my TV. Do you have any other suggestions?
  • pat396 Mar 29, 2009
    I have the same problem with this TV and would like to try and repair it myself. Is there a manual online that would allow me to take this apart ? Any help on repairs would be great,
  • 4,234 Answers
If the picture looks like a 3D one, the problem is a convergence issue. This can be as simple as poor connections at the pins of the convergence ICs or defective ICs. If you can solder you can probably fix this yourself. Please note that there are potentially dangerous high voltages inside the set even when unplugged.
If you wish to attempt the repair, please update this and I will provide additional details and instructions.
Dan
Posted on Mar 02, 2009
Double image,what to do???
If it's picture that's giving a double image from your terrestrial aerial it's called ghosting , you need to move your antenna it's caused by signal reflection and usually happens when your in a strong signal area.
Oct 18, 2014 | Toshiba 40RL858 40 inch led hdtv smart tv...
The picture is "ghosting" or doubled
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 12, 2010 | Toshiba 42H81 42" Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
The picture is double pictured with what appears to be a ghost
projection sets on occation need to be re-alligned. check your owners manual if you have one and re-align your lamps to the test screen that is displayed when you press 'menu' from your remote or from the front of the tv. This should fix alot of it and you may find the color adjustments may need adjusting after re-aligning your lamps. hope this helps. I had one and that sounds like the 'ghost' images I had till I did this.
Aug 11, 2009 | Toshiba 55H70 55" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Double images with red halo outlines
Sounds like your describing convergence ICs. They cost about 10.00 each and you will need to replace both of them. And possibly the resistors that power them total cost under 30 dollars if you do he soldering yourself. Hope this helps.
Feb 10, 2008 | Zenith B50M88W 50" Rear Projection...
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba Model # 42H81 Picture Problem
Can you describe the issue a little more? It may be a convergence issue which is quite common on big screens. But there are quite a few issues that can cause a bad picture.
If it's convergence, you'll be able to tell by going to a news channel and looking at the text. If the convergence is bad you'll see a ghosting like image of 2 or 3 letters for each one that should be there.
Nov 25, 2007 | Toshiba 42H81 42" Rear Projection...
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 43HX71 43" Rear Projection Television Logo
235 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
