Question about Panasonic CJ-A1600 Coaxial Car Speaker
Sounds like the speakers are blown,, how do I replace them
  • Shadow1989 May 11, 2010
    Need more info.  Are the speakers in a car...are they factory...are they aftermarket in a box???
    Problem Solver:
  • 18 Answers
Make of care? model and so on.Live in NH i can show you how to replace
Posted on Mar 03, 2009
How do you fix crackling sounds on the speaker?
Unfortunately, it sounds like the speakers are blown out. All you can do is replace the whole speaker.
How to Tell If Your Car Speakers Are Blown
Nov 16, 2016 | The Audio Players & Recorders
I get a fuzzy sound out of the right speaker. New speakers and wires so that is not the problem
it sounds like a blown channel in the amp.open the amp and see if there are any fuses that might be blown.it might be a blown capacitor which a tech should be able to easily fix
Nov 03, 2015 | Marantz Audio Players & Recorders
Can i fix my subwoofer for my sounbar if its blown
First you need to confirm that it's the speaker that's not working. Get any speaker with similar ohms and connect to the leads.if the replaced speaker works then you can replace with a similar one. If the sounds the same as the original then I guess the output amp is the problem.
Aug 30, 2014 | LG Lsb316 Sound Bar With Wireless...
2005 745i front passenger side speaker making a cracking sound
Either the speaker is blown (most likely) or there is a loose connection to the speaker, or the amp is bad. The connections to the speaker are pretty tight and it's unlikely it came loose unless you recently had some work done near the head unit or the radio, and if the amp works well for all other speakers it's probably OK. Unfortunately you can't fix a blown speaker but you can replace it and you can find a new one online for less than $100
Feb 19, 2013 | 2005 BMW 745Li Automatic
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
My subs sound choppy
Sounds like your sub is "clipping". Clipping is when your speaker is trying to pull more power than the power supply. (head unit, amp) If it sounds good at a low volume and choppy at high volume, supply it with more power. Bigger amp. If it sounds choppy all the time, push gently on the middle of the speaker. It should go back and forth smoothly. If it feels rough, you have blown the coil. Replacing the speaker is the fix for that.
Apr 14, 2010 | Sony Xplode P5 Turbo Subwoofers Car...
Speakers Shot?
Technically, the television should protect itself from doing any damage, but sometimes that doesn't happen correctly.
When you say that they sound like the speakers are blown, can you describe that sound?
If it sounds like they're blown, they likely are.  It's probably about the same cost to repair the speakers (if out of warranty), than to buy an external amp and speakers.
Mar 19, 2009 | LG 32LG30 32 in. LCD HDTV
Possible Blown Speakers?
Any speaker, if abused, can be blown. And if overdriven with dirty power at extreme levels it is not uncommon to burn out the voice coil. You might also want to check out the speaker surrounds. If they go, the speaker works but sounds lousy.
Localize the problem by hooking up two known good working speakers and see what happens. If they also do not work properly or sound like cr-p then the radio is at issue.
Jul 24, 2017 | JBL - MR4W Am/Fm with CD Player White
Panasonic CJ-A1600 Coaxial Car Speaker Logo
90 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
