Question about Fuji FinePix A360 Digital Camera
Usb cord doesn't transfer pictures to computer cammera says checking usb for 15 seconds then says communication error
  • 523 Answers
You have to download the driver of the cam on your pc, and so it will recognize it , if you have the driver reinstall it, if not go to fuji.com and download it, if this doesnot work, replace the usb cable cord and try again, if all this doesnot work, change the whole cable.
Posted on Mar 02, 2009
  • 13,433 Answers
Try using a cardreader instead of usb cable.
  • 10,594 Answers
Please use another usb cable and use another usb port in PC.
Printer Problems
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 AllInOne InkJet Printer
Camera says "communication error" when trying to transfer images to computer. Why?
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jan 10, 2012 | Canon G12 Digital Camera
An error message reads printer cannot communicate with this computer. I have checked the firewaall, the installation and it makes copies so its a connection problem
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 19, 2011 | Lexmark X5470 All-In-One InkJet Printer
I cant scan my picture at the scanner
4. Reboot your pc.
Aug 07, 2011 | Lexmark X2600 InkJet Printer
While trying to put pictures on computer, after 15 seconds of downloading the pictures it disconnects LED says usb error and goes back to question disk or digital
i had this problem before.Mine was that,for some strange reasons, the USB cable from the camera wasnt getting good contact with the USB port on my pc.So anytime i was transferring pictures, its stops and tells me error.All i did was to stop using the cable and i bought a media card read/writer since my pc did not have a media card reader by then.Now all i do is insert the media card from the camera into the reader and transfer my photos
May 06, 2011 | HP CB350 Digital Camera
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
Lost my plug in for the kodak easyshare c330 where can I get one to plug into camera and computer
If you want to download the pictures and movies from the cammera you can unload the memory card from the cammera and insert it in a card reader and then to the usb and without a cord you can do this easily, but you will get the cord in a cammera shop. available in your locality.
Sep 09, 2010 | Cameras
Communication error when uploading pictures on computer
I had the same problem. My problem was that there were more than 1,000 images stored on the memory card. Once I deleted some of the images from the camera memory card, I was able to download pictures again.
Aug 10, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Can't transfer pictures to pc.
you can download the drivers of your cammera on the internet and install them...
try in google or in the website of the cammera´s brand.. there you could find the drivers..
if you still have problems i could help you finding them..
cheers
Mar 24, 2008 | Samsung L73 Digital Camera
Fuji FinePix A360 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
