Question about Daewoo DV-T47N VCR
How do I hook up a daewood vcr to a TV through a Direct TV
...Satellite hookup. I tried everything, nothing works.
    Problem Solver:
  • 9 Answers
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Posted on Jun 16, 2009
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Hooking up my x-box 360 through Direct TV
Ok i had it installed today too....i already had it so i have experience with it....get a vcr....in th eback there should be some ports for AV cables hook that up and get one of those cords that look like the direct tv cords and put that in you VCR out to tv...and screw it in with your hands in your tv.....when you have your VCR on the direct tv wont show and if your direct tv is on when your xbox and VCR are on it still wont so turn off the VCR to get direct tv back again.....im 13 and i figured this out...hopefully this helps a bit
Sep 26, 2009 | Microsoft Xbox 360 Console
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
May 26, 2009 | JVC TH-G30 Theater System
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Cant get dvd to operate
Have you changed the TV input to AUX? If there is a VCR hooked up with your satellite box it has to be on Line or Aux too. Make sure these are in place before trying the DVD player
Nov 18, 2008 | Zenith B27B40Z 27" TV
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
VCR not recording higher-numbered channels
Yes coming in her VCR with Cable or ant, if she has satellite it would be different. Going out to tv from VCR. Then in is Input the Out is Output. RF cable connection or A/V inputs(jacks) either one same way of hookup.
Sep 15, 2007 | Zenith XBV442 DVD Player/VCR
Panasonic NV-J45
Has VCR to TV hookup been changed? Cabling errors will result in no display from the VCR (no tape video/audio, no menu display). If you are using the TV aux/VCR input connections, you must select this input before anything from the VCR will be displayed. If you've verified hookup is correct, then perhaps something is afoul with the VCR. Try hooking it up to another TV.
Sep 03, 2007 | Televison & Video
Daewoo DV-T47N VCR Logo
336 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
