Question about Hotpoint WMA32 Front Load Washer
Drum bearings need replacing
The machine is very noisy how big ajob is this?. does the drum come out thro the top or bottom thanks
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
Drum noisy and appears to be jumping all over the place
There is a three-legged yoke that is behind the spinning drum. Sounds like it's on it's last leg, and will soon comletely break off. Big do-it-yoursef job, suggest repairman or new machine with warranty.
Jun 13, 2014 | Hoover H130E Front Load Washer
Washing machine Spinning cycly drum wobbles noisy
It sounds like one or both of the suspension struts has either broken or come away from it's mounting. Inside the washing machine there are a couple of concrete blocks used to counter balance the motion of the drum when it is turning. The suspension struts (just like a cars) dampen the effect so that the machine does not wobble all over the place. The struts (two normally) are firmly anchored to the washing machine chassis at the bottom and the other ends are attached to the drum itself, usually on either side. Check that these struts are not damaged and that the mounting bolts etc. are not loose or missing.
Jan 19, 2014 | Washing Machines
Noisy/shaking dryer
There is a bearing on the drum and guides at the front of the drum. You will have to remove the top of the machine to see the drum parts. Unplug it first. The top then pops off. Look at the back of the drum to see if the bearing is bad.
Jul 22, 2013 | Dryers
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Very Loud banging on washing machine spin cycle
Ah,,,,Sounds like drum bearings havee gone the circles iassume is oil from the bearing it will be very noisy on spinen and a lot of play on drum ..quite a big repair..hope you get on ok
Sep 30, 2009 | Washing Machines
Very noisy and leaking
Water pump may be leaking. Check idle pulley and big counterweight spring that stedies the drum. Go to www.appliancepartspros.com for a diagram. Have model number ready.
Jun 23, 2009 | Amana NAV2330AW Top Load Washer
Door will not open. lock handle floppy.
take top off and see if you can feel for the door peg sticking thro the interlock and operate by hand.
also, you can chew away the door handle and operate the door peg with a small screwdriver.
the door handle kit will need replacing anyway
Sep 11, 2008 | Zanussi WJS1397W Front Load Washer / Dryer
The drum will not spin round
drum bearings are gone big job, may not be worth repairing.
Mar 01, 2008 | Electrolux EW1000i Front Load Washer
Hotpoint WMA32 Front Load Washer Logo
328 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
