FixYa.com
Tags:
Toshiba External Floppy Drive
Installing OS on Toshiba Portege 3480ct
By Grant - usenet poster
I'm thinking of buying a used Toshiba Portege 3480ct which comes with no OS,
no floppy drive and no CD drive.
If I bought a USB CD drive, would it boot from that? (I'd rather have a USB
CD drive than a PCMCIA one as it could be used with a PC as well)
Any comments about this machine?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Melissa
Melissa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Can't boot from a USB device.
Nice, small, light, pin sharp screen (are your eyes good?) and quite sturdy.
A decent performer if you aren't into games - you might just be able to play
Quake III at pretty dismal settings ;)
The most efficient route to installing an OS would be to remove the laptop's
hard-drive, obtain a laptop drive to desktop IDE cable or adapter and
transfer the install files via a desktop PC. Make sure the drive is
formatted to a bootable DOS partition, from where you can access your
installation directory :)
If you plan on installing XP I would advise including and using the smartdrv
DOS utility as this will considerably speed up installation. So, copy the
entire "i386" directory from the installation CD along with smartdrv onto
laptop drives bootable partition. Replace the drive back in the laptop (of
course!). Reboot, at the DOS prompt run "smartdrv", then "CD i386", then
execute "winnt" to get the installation up and running.
HTH,
AlexQ.
~ Reply-to valid ~
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
Can anyone confirm this? - the vendor told me that it COULD boot from a USB
cd drive. Is that definitley wrong?
Solution #3
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
It all depends on what your paying for it. You need to be sure once
youve got it that getting all the missing item wont cost you more than
buying one complete.
What you are trying to do is the hard way. Id never consider a laptop
that wasnt complete unless it was at scrap price. Just my 2p's worth.
Solution #4
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Don't think there is any way a USB CD drive will boot on this machine.
USB floppy should be OK, but it may have to be original Tosh one (Part
No : PA3043U-1FDD).
Suggest you have a good look around the system settings to see what
options are available.
If you boot from floppy, you will still have the problem of getting a
USB CD recognised in DOS - also there may be only a single USB port (?).
Make sure you get one with real mode drivers available! If you get that
far, I suggest you copy the OS files to a folder on the HD and install
from there - had to resort to this method on my 3110ct, which has a
similar (lower) spec.
Best of luck
Vaughan
Solution #5
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
It will definately be a TFT screen. I don't think there ever was a Portege
that used a non-TFT screen.
AlexQ.
~ Reply-to valid ~
Solution #6
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
Make sure the screen is TFT, and not dualscan.
Remove "nospam" from return address.
Can you Help with these Floppy Drives problems?
Floppy Drives
applications of linear...
1. if a rectangle has a length... Answer This...
Floppy Drives
floppy drive
The floppy drive will not open... Answer This...
Floppy Drives
word problems regarding a...
If you earned an average of... Answer This...
Floppy Drives
maths linear equations
A positive number is 5 times... Answer This...
Floppy Drives
konica floppy photo disks
I have photos on the old konica... Answer This...
Repair Service
Find Floppy Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
