Question about Avaya 4610
Log Off I logged off by mistake. Now it reads: Ext= *=OK New= I'm not sure what I need to do to get the phone back up.
  • Anonymous May 11, 2010
    Enter the extension number followed by the "#" sign. But, you will need to input a password next, so if you if you dont know that, you are out of luck. You will need to talk to the admin to find out what it is.
  • 33 Answers
If you remember the extension that was assigned to the phone previously try entering that followed by 1234else ask your it admin for help
Posted on Feb 23, 2010
  • 79 Answers
If you have never created a password try just the #sign for the password
Posted on May 28, 2009
If you know the extensions password, press the extensions number and the "#" sign. Then the password and the "#" sign.
Posted on Mar 12, 2009
How do i scan and send to email
Scan setup. create a folder on c drive of computer example called scan. then share folder with everyone and make sure it has read/write permission. Then on copier push button says user tools/counter then system setting/administrator tools/ address book management /new program / enter a name then go to folder smb then browse for computer select it. then will ask to log in. which is log in name and password that you use to log on computer with. Note user name needs to be letter or numbers only no symbols or spaces. Example user name: scanner password: scanner123 then select scan folder and press ok then press ok again to save setup.
Sep 30, 2014 | Ricoh Aficio Mp C5000 Color Copier - 129k...
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
How do I change the ext number on a 3com phone?
You have to log in to the phone system as administrator and go to the users tab. You can change it to an unused ext. at that point.
Jul 22, 2010 | 3Com NBX 2102 IP Phone
T7316E Corded Phone
When the display shows LOG: it means that theres no mailbox attached to the extension. When logging in as 120000 theres the possibility of changing the administrator password.To build a mialbox for ext. 25
press feature 983 > log: 120000 > mbox > add > 25 > reset password: next > type: subscriber > ext. 25 > cos: either 1, 3 or 11, >
name: first and last of the employee >directory: y >message light: y > alt ext: none> transfers: blind
Feb 23, 2010 | NorStar T7316E Corded Phone
Changing the names fixed to internal extension numbers
If you can not log into the programing tool to change it that way then you will still need the Installer password. However from the main ext typically the first ext or 101
hit the Program soft key just below the LCD
push * then #
password
004
ext number you wish to change
type in new name
ENTER
END
Apr 14, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7630 Master Phone
Sure. It requires an Operating Manual (OM) and some programming. If you need the manual, here's a link http://public.carl.airpost.net/TDA/200_TDA_OM_06-12.pdf
On page 158 and 168 you can set up the features of the phone.
In order to do that, you'll go back to the phone that works, and press PROG and each button and write down what it says.
It will say things like EXT-102, LOG IN-100, VTR-165, etc.
If the buttons are labeled, note what it says, then move over to the phone you want to program. Press PROG, the button, then dial the codes from pages 168 forward for each function. It's not that difficult, for example, a DSS for ext 101 would be 1101 STORE, call log is 30100 STORE (or similar).
Each button changes when you press STORE and the feature will move if it has already been stored in another location. HOLD PROG backs you out of programming.
Please rate this solution or acknowledge that you have the manual if you need it as this link will be taken down when you do or by 2/23 if you don't..
Carl
Feb 17, 2009 | Panasonic KX-T7630 Corded Phone
How to delete individual log from call log in Nokia N71
Download from Nokia Ovi Store the tiny tool "Delete Single Log", this is what you want. It can delete individual call log / sms log entry.
May 17, 2008 | Nokia N95 Cellular Phone
SAMSUNG ER-5115 SAM4S CASH REGISTER LOCK-UP
Turn off the machine. Hold down the lower right key on keyboard. Turn key to P. Turn on machine. That should clear it out. It will also log you off you will need to log back in. Make sure you correct your mistake
Mar 08, 2008 | Computers & Internet
Call log
Silly. Plain silly. The question is how many other things does he have installed on the phone? Any themes, excess profiles, large numbers of pictures, several third party applications... This will all contribute to system resources being depleted. If he has a factory default set up with less than 100 photos and zero video or music -- he is probably selling you a dream. If however the opposite is true, the phone may be dumping his call log. Mine DOES infact to do that when my memory is getting low since loading a couple of videos and a Bob Marley theme. I hate it. I am trying to retreive a call that I lost because of that exact thing. Think of it as being a kin to a Blue Screen of Death on a PC.
Feb 11, 2008 | AT&T Blackberry Curve 8300 Smartphone
Avaya 4610 Logo
393 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
