Question about Brother MFC-3240C All-In-One InkJet Printer
Problems with cartridges
Hi. We havent used our machine in a while. The cartridges will drip ink, & don't appear to be dry. The machine keeps telling us there is "no cartridge". So upon removal & reinsertion, it asks if we changed the color, we reply no, & it still doesnt recognize the cartridge.
ANy clue?
  • 408 Answers
Try hitting the button that says you did change cartridges.  The ink level indicator might be off if you do, but that might fix your problems.
Posted on Mar 02, 2009
Want to know how to manually clean printer head
You can, but the objective is to soften the dried ink, that blocks the tiny ports.
In my estimate the alcohol will dry too fast.
Printer UNPLUGGED from power, and you may wish to don some gloves.
(Dishwashing gloves?)
The ink likes to go everywhere.
Remove the ink cartridge/s.
As you can see, the copper metal strip area, on the ink cartridge; has TINY little holes in it.
I use a clean soft static free cloth, and soak the end I'm going to use; in as hot a water as I can stand.
Then reduce the water in the cloth, (Squeeze), so the wet area, is just damp.
Wipe across the copper area, and it's tiny ports.
Wipe across once, then find a clean area on the cloth; and do so again.
Keep wiping until cloth comes away clean.
I also do the same on the metal area, of the printer; that the metal area of the ink cartridge touches.
There are matching tiny port holes there also.
Keep wiping, adjusting for a clean area after each wipe, until cloth comes away clean.
I then follow with a can of compressed air for computers, and make sure the areas are DRY.
Q-tips, and Isopropyl alcohol, (Rubbing alcohol), sounds more intelligent, to me.
However the amount used may fill up a small bag, IMHO.
I know what you're thinking. Is this guy N-uts?
Water and Electricity do not mix!
(Actually they do. Water is an excellent conductor)
I watch to make sure there are no drips from the cloth, when using it. Have a dry cloth handy for the other hand, if they do.
I also make SURE the areas are DRY, before reinstalling ink cartridges.
I find VERY warm water helps break down the dried ink.
Always willing to learn something new, however.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | E-Machines eMachines Desktop PC
Hp2210 all in one. i put a new ink carthridge in. it keeps telling to alighn carthridges. i press enter & the printer alighns the carthridge # prints the report. the printer keeps telling me to alighn...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Ink Cartridge error messages
Don
Nov 30, 2009 | HP Officejet 6310 Printer
I keep getting the error message "An ink cartridge appears to be missing, not detected, or incorrectly installed" I am sure that I have installed both ink cartridges correctly though. Any thoughts?
Are you using a factory new ink cartridge?
Please consider the following:
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
Had black ink cartridge filled, but now the
Don
Nov 18, 2009 | HP Photosmart C7250 All-In-One Thermal...
Printer head problem?
If you are using factory new cartridges, then please call Canon Technical Support for assistance with the warranty on the Canon Cartridges
Don
Nov 09, 2009 | Canon Pixma iX5000 InkJet Plotter Printer
HP C4480 printer.Refilled the cartridge,how do I tell the printer
Don
Nov 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
"Color Ink Probelm"
Don
Oct 24, 2009 | HP Photosmart 2575 All-In-One Printer,...
Mfc not used for 3 years. seems be printing but no ink comes on paper
It is my belief that ink has dried in the all-in-one printer ports.
Ink flows through minuscule, little ports, (Holes), in the ink cartridge.
These are covered by metallic foil tape when you get a new ink cartridge, that you are instructed to remove, before installing.
On the all-in-one printer, it has matching holes. When the ink cartridge is installed, it's holes line up with those holes. I think ink has dried in these holes, on the printer.
It would be my suggestion to clean these holes. It's not hard, you use a warm water, damp clean cloth.
-> Printer Unplugged from power
Open the printer to remove the ink cartridges. It is at this point, that I would advise donning a pair of rubber gloves. (Dish washing?)
Helps to keep the ink off of your hands, and fingers, just in case.
(The ink cartridges are open now)
Remove the ink cartridges. Soak a clean, lint free cloth, in as warm a water as you can stand. The warm water helps to dissolve old dried ink. Wring the cloth out until it is damp, NO drips.
You should be able to judge where the holes are in the printer body, by the area on the ink cartridge. Wipe in one direction, on this hole area. (The holes are so tiny, that you won't really be able to see them. {Or maybe I need better glasses! lol!}
Wipe what you think is the area. Looking at the ink cartridge, and where you removed the tape from the cartridge, you'll have a pretty good idea.
Once you wipe across, and pick up ink, I suggest using a different clean area of the cloth, and do it again. I would do this procedure, until there is very little, or none, picked up by the cloth. (Ink)
Once you are satisfied that this area is cleaned, I would use a hair dryer to speed up drying. You don't want this area to be wet, when you reinstall the ink cartridges. Hair dryer on low, keep it constantly moving back and forth.
When you are satisfied it is dry, reinstall the ink cartridges. Close the printer case. Plug it back into power. (Hands dry, no gloves. Not trying to insult your intelligence)
Turn the printer on. Wait until it resets itself. I would now go to the Diagnostic section, and do diagnostics. Then align the heads, and print a test.
May 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
Remove and check cartridge
I suggest that the inkjet ports on the ink cartridge, and perhaps on the printer, are clogged with dried ink. The ports I'm speaking of are tiny, minuscule holes, in the ink cartridge. Ink comes out of the cartridge, and through these tiny holes. The size we're talking here, is almost microscopic!
On the printer itself, there are holes that match. Match the holes for the ink cartridge. These become clogged also.
I would like to suggest this. Works for me, printers in my shop, and to many, many people I've suggested it to. (I will repair basic problems on a printer. The computer itself is my forte)
Printer UNPLUGGED from electricity. Open the printer body, remove the ink cartridge. If there is more than one ink cartridge, you may want to remove them as well. Give yourself room to work.
(This isn't really like work. You'll see what I mean)
Use a clean, lint free, cloth. Soak it in very warm water. Actually as warm as you can stand to the touch. Wring the cloth out until it is just damp. No drips of water are present. I suggest you don a pair of rubber dishwashing gloves. Keep any ink from getting on your hands, or wrists.
On the front of the ink cartridge you should see a brass strip of metal, or brass contact pads. If the cartridge has the brass metal strip, the holes are probably in it. If it has the brass pads, the holes are probably nearby. Wipe the area the holes are in. If there is no obvious area that looks like where these holes would be, wipe the entire area that contacts the printer.
As you wipe, you should pick up some ink. I suggest you use a fresh area of the cloth, and continue. When you are satisfied the ink cartridge holes are clean, set the cartridge aside.
Now with a clean, fresh surface, wipe the area on the printer where the ink cartridge meets.
You may want to follow up with a clean, lint free dry cloth on the ink cartridge. It needs to be dry before reinstalling.
You may want to use a hair dryer set on low heat, to speed up the process of drying the printer out.
Keep the hair dryer constantly moving, and about a finger length away as you use it.
I Do Not suggest the hair dryer trick for the ink cartridge.
When you feel satisfied that everything is dry, reinstall the ink catrtridge. Close the printer, and make sure it's down tight. Plug the printer back into electricity. Turn the printer on. Go to the Diagnostic Tools section, and run diagnostics.
Do the alignment test, and print pattern test.
In your Help section, it will show you where the diagnostic tools are, and how to do the alignment test.
Apr 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
