Question about Car Audio & Video
Bass hits, but quits.
I have this set up.
Chevy '05 Cavalier
Pioneer DEH-P3000IB Head Unit
1 Sony Xplod XM-Z1852 Amplifier
2 American Bass XO's (10") DVC
Each sub is wired on a seperate channel at 4 ohms for each coil. This puts a 2 ohm load on each channel. Can I even run this without damaging stuff?
Secondly, in this set up, when I play music, long bass notes (Think "A Milli"), it will hit on the first part, but then stop. This only happens when I'm driving. Parked it plays just fine. I've adjusted levels on the head unit and amp and it still messes up if the volume is anywhere above about 15 (out of 62). Why is it doing this, and how can I fix it?
I've tried everything. Any help?
    Scholar:
  • 61 Answers
You will need a larger ground wire also try bolting it down in a new location if you have to scrape away any paint to bolt it to metal
hope this helped
Posted on Mar 04, 2009
Not enough bass. should i run a capacitor.adjust my amp and what to set it at for max performance
Turn up the gain on your amp until you get the amount of bass you want or until the sub starts to distort. If you do this and you are still unhappy with the bass, you will need a bigger amp or better subs.
Dec 04, 2013 | Sony Xplod XM-1252GTR 2-Channel Car...
I have a sony 2/1 channel power amplifier (XM-2165GTX) that will produce sound untill my pioneer headunit (deh-3050) hits 25 in volume..the sub then goes into protection mode and will not turn off..not...
Not enough power going to the amp..?
Solutions:
1) Your negative ground wire needs to be in a better spot.
scrape paint from the grounding surface.. This will ensure better contact between the negative power wire terminal and the vehicle ground.
2) Get thicker wiring cables.. for Positive, and Negative
3)Turn the gain right down.
Jan 12, 2010 | Sony XM-2165GTX Car Audio Amplifier
Subwoofer doesnt hit hard at all with this amp.
set gain to match head unit.its not a volume control.turn bass up.on unit and amp.and not knocking what you have but sony well theres much better.
Nov 14, 2009 | Sony XM-2200GTX Car Audio Amplifier
Sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
Jun 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod
If your still getting a green light, it at least sounds like the amplifier portion may still be funcitonal. Perhaps your inputs are blown. If your comfortable with electronics, pop the cover, and try patching a signal directly to the amplifier stage. and of course check your source.
Jun 20, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony XM-1652Z
What head unit do you have?
Is there a dedicated subwoofer output?
If not, have you switched the rear output to sub output?
Is the amplifier set to LPF (low pass filter), and the gain turned up?
Many things can be wrong, but the fact that there is anything coming out of the subs is a good thing.
Start at the beginning - Head unit, then check amplifier gain/crossover setting.
If you are using a hi level adapter on factory radio, is the Bass on the radio up? is the output gain on the convertor up?
Jan 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod - cd reset
UNPLUG THE HEAD UNIT HARNESS FROM THE HEAD UNIT. WAIT 30 SECONDS REPLUG AND RESET and hold the reset button down for 5 seconds
Jul 01, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
