Question about Grilling
Change from natural gas to propane
I want to change my kenmore elite grill from natural gas to propane. What is the easiest way to do this?
The grill is 1167 square feet and the model number is: 141-176901
The seraial number is: SU1L000287RS0339
  • May 11, 2010
    hi my name is mark, was this grill originaly a lp grill then converted. if not it will be pricey to convert to lp. around 300. to 390. dollars leave e-mail and i will explain.
afwings
SOURCE: gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Posted on Oct 31, 2008
jyackle5
  • 8197 Answers
SOURCE: grill model 720-0163 need to convert from propane to natural gas
Go to jenn airs web site an order a new natural gas regulator and or-faces.
Good luck and please rate fixya!
Posted on Feb 24, 2009
  • 10 Answers
SOURCE: uniflame gbc820w propane to natural gas adapter question
Most major hardware stores that sell grills have a universal conversion quick connect hose and gas line adapter fitting.  That.. you can probably handle.   Next you need to install a quick connect adapter from the house gas line or meter (unless one is already there for you).  Otherwise you may want to call your local gas company or fireplace/grill store to send someone out.    Last all LP to NG conversions require the orifices on the back of your grill's valves to be changed to larger holes.  (LP has more pressure thus small holes and NG must be larger.)  The trick is getting the precise numbered drill bit diameter(45-55) for your particular grill.  You can look on your manufacturers web site to provide this info.  Often times they can sell you a new set of orifices, predrilled, to the exact diameter for conversion.  Drilling out orifices is usually cheaper and pretty easy if you know where to find the bits (internet or specialty tool store).   Sometimes your local gas company or fireplace/grill shop will provide this service as well. Hope this helps, and good luck.
Posted on Mar 29, 2009
redbeard00
  • 957 Answers
SOURCE: Can I convert my MDBQ-30 NG grill to LP Gas
yesL contact your local propain provider and/or plumbing supply Co. They need to see the valve and they will let you if they can convert it or not. If not they will sell you an L.P. style valve.
Posted on Apr 25, 2009
SOURCE: NAtural gas vs propane
I'll trade my propane regulator for your natural gas hook up.
Posted on Jun 02, 2009
I have a weber s 620 made for propane but it was converted to natural gas. i had to replace the manifold and it is made for a propane so the grill is not getting hot what can i do?
You need have the orifices that match the fuel you're using - either propane or NatGas. Once you have the correct orifices installed, you should get the proper fuel flow. The propane is at a higher pressure, so the orifice for it is smaller than the ones needed for the lower pressure NatGas. Contact Weber for the kit needed for your model grill.
May 21, 2014 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
How do i switch from propane to natural gas on a Kenmore he3 Dryer
You would have to change the gas train out to a natural gas one, the orifice sizes are different.
May 02, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Apr 01, 2011 | Grilling
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 22, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
CHANGING FROM PROPANE TO NATURAL GAS
check owners manual- its one or the other, IF no natural gas is writen in manual- its a propaine for life!! You will have to purchase a natural gas grill-
Sep 16, 2009 | Kenmore 632 sq. in. 16324
Re: hi
How old is the grill?
When was the last time you cleaned the grill?
Is it Liquid Propane or Nat. Gas?
Apr 19, 2008 | Ducane 30400040 Stainless Steel Grill
Grilling Logo
142 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
