Question about Kenmore 62602 Electric Dryer
Kenmore Dryer Model #110 62922100 Won't Start/Run
The inside drum spins freely and there was no smell or sound like a burning out motor. There was a water pipe rupture behind this dryer earlier, could that have blown the internal fuse? (Not much water, certainly not enough to wet the inside of the dryer operations) Main fuses are fine, but no response. How could we tell if it was the door switch? Thanks for any help!
  • 4 more comments
  • broadreach25 Mar 06, 2009
    The vent hose has been disconnected and the dryer still won't start - there is no response at all when the dryer start button is pushed, just a click.
    How do you check the fuses and where are they located?
    How do you check the door switch, wiring harness, etc?
    I appreciate all these suggestions, but could use the directions on how to do these things so that we could check them!
    What do you mean by "check out" the power plug and cable - both are in good shape visually from the outside.
  • broadreach25 Mar 07, 2009
    The drum turns freely, not that. The problem with the "solutions" that I am getting is that they don't tell me HOW to check the things they suggest.
  • Kenmore Master
  • 19,396 Answers
Hi there, sorry but I have sse the problem onl now.
If the machine has no power at all, then it is a wiring problem.
If there is no power at all try a different power outlet.
If there is a fuse inside power cord, replace it.
To "check the power cord" as somebody correctly suggested you need to use a device called Multimeter.
If you find nothing in there , then you have a broken contact on the internal wirings.
If instead you have power on the machine but it does not start:
Test the door latch, ensure it is closing well, eventually the latch must also be tested with a Multimeter.
If you find nothing in there, open the back panel and replace the thermal fuse inside the machine.
If still no start, then usually you have a faulty control board.
You can find parts for your appliance by entering model number on this website.
Posted on Mar 09, 2009
  • 217 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Posted on Mar 07, 2009
  • 10,515 Answers
Normally when a dryer starts to exhibit longer dry times, then suddenly stop working, it is an indication that the Thermal Cut-Out has blown. The TCO acts as a fuse for the heating element circuits. When an overheat condition occurs, normally the hi-limit thermostat will open to shut off the heating element. This is how the dryer regualtes its heat. However, if the hi-limit thermostat malfunctions, the TCO will blow, It is not resettable, and has to be replaced. This also means that the hi-limit thermostat could be suspect and it should also be replaced at the same time. Normally, when you go to replace one or the other they are sold as a set. This still does not rule out the possibility of a bad heating element, either.
However, you said the dryer additionally does not start. With a blown TCO or heating element the dryer will still run, but will not heat. I'll get back to this in a minute...
Now...if your dryer has been having problems drying, the first thing you need to check is the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell you've experienced. If trapped lint is ending up on the heating element it will smolder and burn. I recommend the ducting be cleaned thoroughly about once per season. That's 4 times per year. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. One way in determing air flow is to remove the vent hose from the back of the dryer and start the unit (of course, you need a working dryer in order to do this). The air should be forceful and slowly warm up to about 140 degrees. If the air flow is weak, you may have a clog inside the air baffle of the dryer (this is where the lint screen slides into). If the air flow is good, reattach the dryer hose and check at the output of the dryer vent as it exits your home. If the air flow is weak or non-existent then you know you have a clog in the vent line somewhere. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint.
Now, in determing which component is bad in your dryer. If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side.
The heating circuit is set up and troubleshot as follows:
Heating Element (located inside the heater box) - Resistance reading should be 9-13 ohms.
Thermal Cut-Out (located on the heater box) - Resistance reading of 0 ohms.
Hi limit Thermostat (located on the heater box closest to the heating element leads) - Resistance reading of 0 ohms.
Operating Thermostat (located on the air baffle) - (May have 4 wires attached to it). Will read 0 ohms across one set of leads, 7 ohms across the other.
*Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms.
*If the Thermal Fuse blows, this will shut down the entire dryer. This is your likely suspect.
Here's a few things that will cause a dryer not to start at all:
1. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
2. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
3. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
4. Bad Timer - If the timer does not function the dryer will not start.
5. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
6. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
I just threw in those other items to give you some other things to consider. Troubleshooting is always an exact science as symptoms don't always indicate what you think the problem could be. The reason I keyed in on the heating circuitry was the intial symptoms you started with. Longer dry times are usually associated with poor air flow which usually causes something to eventually blow. I hope you find this information helpful. Please post back with any comments that I may assist you further. I hope this isn't confusing to you.
One thing I forgot to mention. Make sure you UNPLUG the dryer BEFORE you attempt to trouble the heating circuits. Live voltages are present even with the unit turned off. I hope I'm not insulting your intelligence.
Thanks.
  • 296 Answers
Can you hear it run but the drum dont turn? If so then check the belts that connects the motor and drum
Posted on Mar 06, 2009
    Genius:
  • 1,550 Answers
You will need to check the door switch, timer, motor & wiring harness.
This will require using a volt/ohm meter for diagnosing.
  • 1 more comment
  • SAM ANDERSON Mar 06, 2009
    Test to check the door switch
    Open the dryer door & push in on the door switch lever, you should hear the click.
    To test fuse
    You will need to unplug the dryer and
    remove the top panel. Screws at the very back edge of the top panel
    secure it to the dryer frame. Remove these screws and then pull the top
    panel back and off of the dryer. The thermal limiter is located on the
    top of the back panel of the dryer. It will have white wires connected
    to it.
    Remove at least one wire and measure the resistance across the leads of
    the thermal limiter using a volt/ohm meter. You should measure
    continuity (near zero ohms of resistance). If it is open (measures
    infinite resistance), then it will need to be replaced.
    Hope this helps .
    For further help feel free to ask .
  • 916 Answers
Check the fuses in the machine.
  • 154 Answers
There is some clog on the tube check that.
  • crysiszone Mar 06, 2009
    check out the power plug and power cable.
    Top Expert:
  • Kenmore Master
  • 77,169 Answers
Either the motor is bad or the capacitor start for the motor is burned out, pull the motor and test it, it is very easy.
  • yadayada
    yadayada Mar 06, 2009
    there is noway u could have tested the dryer motor so quickly, do the tests u may just find I am right.
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
Kenmore model 110 dryer won't start. Hums a bit, then nothing. Starting to get a slight burning smell too. How to remove the top console to get to the push to start switch?
From what you described it sounds like your drum is seised, try turning it by hand. If it is seised than you will have to check to see if you burnt your motor. Good Luck
Sep 24, 2011 | Dryers
Heat works on dryer but won't spin... the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Kenmore Dryers
I have a Kenmore Dryer Model number 66902691 that has a burning smell when it is running. All lint was just cleaned out of it, but it is still smelling!
This might be caused by a seized idealer pully, located on the bottom of the dryer drum. A belt wrapes around the drum and across the idealer pully and then on the motor pully. If the idealer is not turning freely, it creates friction and eventually burns the belt in half.
Hope this helps
Apr 29, 2011 | Washing Machines
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Dryer turn on but would not spin
When the dryer will not spin the most common cause is a broken dryer belt.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 14, 2009 | Kenmore 63942 Dryer
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Kenmore 62602 Electric Dryer Logo
159 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
