Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Loading paper this machine has a spindle or rod to load a roll of paper onto, and I have tryed to figure out how to put the roll on his rod. On each end of the rod, is something that looks like A KEY, but it does not come off ! How do I load my michine?
  • cschinck May 11, 2010
    I have this same copier but I don't know what you mean by a rod or spindle to load a roll of paper on. It should have a paper drawer at the bottom and paper rollers that feed paper up from it.
  • 239 Answers
I know this product and I have serviced it before.
I am a retired Xerox Service Representative.
Can you give me more details about this area.
I am not familiar, "by a roll of paper."
This machine can be fitted with one or two paper trays and has a by-pass feed tray, and a document feeder.
I do not know of roll paper that can be fed in this machine.
Thank you, I ook forward in hearing from you to resove this problem.
Posted on Oct 16, 2009
Roll feed Paper will not load
You need to make sure that the leading edge of the paper is straight.If the leading edge is crooked or angled it will often cause a load issue. Also make sure that the roll is mounted properly on the spindle.h
Jun 26, 2015 | HP "Designjet 111 24"" Wide-Format Inkjet...
Error 45.1.03 for t770
switch off the machine, remove paper and spindle of both roll & 2, close the roll covers, switch on the machine wait until ready mode appears, select load media, select roll 1. Load spindle in in the bank, verify properly seated or not, insert paper to load wait to printer perform load media..if successfully loaded issue closed..:Other services are not advisable to users only professionals can resolve the issue..
Feb 01, 2012 | HP DESIGNJET T770 Printer
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    We spend a large portion of our day desperately trying to load paper and always getting the "paper loaded with too much skew" message. The paper is straight and on the blue line, i'd love to trun...
    What type of paper are you using? It's common on cheap canvas or fabrics. Make sure the beginning of the roll about 10 inches must be straight in right side (blue line side). The paper slips upward freely and straight before lowering blue lever. Also this problem appears when your room is dry (low moisture) then PP sticker and some photo paper will curl. This checking feature is very useful for printing on whole roll in a single feed.
    Mar 22, 2011 | HP Designjet Z6100 InkJet Printer
    Printer header path type 1, 2, and 4 prolem request for feeding back
    If the media does not feed into the in-feed slot in the media cabinet, try the following:
    • Make sure both roller levers are lowered to open the in-feed slot.
    • Trim the leading edge of the paper so it does not get caught in the slot.
    • Insert the media evenly to avoid angles. Do not insert one corner and then the other.
      NOTE: A beep means that the printer has detected the media in the in-feed slot. The printer will only beep once in a load cycle, if media is removed and reloaded the printer may not beep again if the load process is not re-started through the front panel.
    Media does not advance If the media does not advance far enough into the in-feed channel in the media cabinet, the paper is slipping and the rollers do not grip the media. Try the following:
    • The pre-tension might be applied incorrectly. Always apply pre-tension by turning the star screw on the left side of the spindle. Never apply tension by turning the media roll or the spindle disks.
    • Clean the rollers using the cleaning procedure.
    • If the media being used is heavy coated, try changing the media.
    Media jam in the in-feed channel If there is a media jam in the in-feed channel, try the following:
    • Turn the multi-roll feeder off using the power isolator switch on the connector panel at the back.
    • Open the media cabinet doors and lower the roller lever on both sides.
    • Turn the spindle to pull the media out of the in-feed channel and to collect it back on to the roll.
    • If the media is blocked, place the spindle in the park position for better access to the in-feed channel, and then pull the media edges in a downwards direction on both sides.
    • If the media cannot be reached because the roll has finished and it has not been ejected from the front of the printer, open the rear cover and try to remove the media from the motion control assembly.
      NOTE: Do not insert media with crumpled or damaged edges, trim the media first.
    • Make sure the leading edge is trimmed straight.
    • Make sure there is even tension across the width of the media.
    • Make sure media is aligned (the same amount of media is fed across the width).
    • Apply pre-tension the media.
    When the printer is going to be unattended for a long period of time, it is a good idea to load and unload each roll using the LOAD/UNLOAD commands from the front panel (if the media loading procedure was not completed when prompted by the printer). This will ensure that each roll of media loaded is correctly aligned and that the printer is capable of loading/unloading each roll when requested by the print jobs in the queue.
    Media misaligned When a "Misaligned?? message is displayed, the printer unloads the media. Press ENTER to continue and the printer will display the "Ready for paper?? status message. Do the following:
    • Check for even tension across the width of the media. If there is less tension on one side than the other, then the media is not straight in the in-feed slot.
    • There is a hole on the right side of the in-feed slot. Make sure the edge of the media is aligned with the left side of this hole.
    • Lower the roller levers on both sides and adjust the media so that tension is even across the whole width. Turn the spindle disk quickly two or three times away from you and then two or three times in the opposite direction. This will help to create an even tension.
    • Lift the roller levers on both sides and try to load the media again.
    If this does not solve the problem, remove the media from the in-feed slot and repeat the loading procedure. Make sure the roll is against the right hand spindle disk (fully inside the roll core), and do the same for the left hand spindle disk. The printer verifies correct alignment using the blue line on the right hand side of the printing area as a reference. Media does not unload correctly If the media does not fully unload from the in-feed channel in the media cabinet, check the following:
    • Maybe there is not enough pre-tension. Always apply pre-tension by turning the star screw on the left side of the spindle three or four times (or more if the spindle is on a low retainer bracket). Never apply tension by turning the media roll or the spindle disks.
    • The spring applying pressure on the retainer bracket is loose and the spindle is slipping in the retainer bracket. Turn the multi-roll feeder off and turn the retainer bracket screw one turn in a clockwise direction.
    Partial or blank prints If the print is partial or blank, check the following:
    • Check the multi-roll configuration in the printer driver: Check that the Has Multi-Roll Feeder check box is selected.
    • Check default roll configuration: Check if a roll is installed for the roll configured as default. If a roll is not selected from the printer driver, the printer will try to print to the default roll, and if no identical roll is available, it will not print the job.
    • Check Productivity mode settings: If the mode is set to normal and the roll has finished, the job cannot be printed.
    • Check cable connection: Check that the printer and any network cables are securely connected to the printer. Make sure the parallel cable is connected between the multi-roll feeder and the printer and ensure that it is also firmly connected between the computer and the multi-roll feeder.
    • Check media configuration: Make sure the media rolls are configured correctly.
    • Check document file: When printing files that are generated with versions of printer drivers for printers without multi-roll feeders, the header section of some file formats already contains information on the media. In these files, roll or sheet information corresponds to roll 1 in the multi-roll feeder. These files will print to the Default Roll. HP advises that the top roll (roll 1) is used as the default.
    Dec 09, 2010 | HP DesignJet 1050c plus InkJet Printer
    I can't figure out how to get the belt back on...I can't figure out how to get it past the spin shaft
    Put the belt on the thin motor spindle first. Once this is done, lift the edge of the belt just onto the left edge of the large wheel that drives the drum. Now spin the wheel clockwise and ease the belt into place. It will go on surprisingly easily
    Oct 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Cannot load new roll of paper
    It is actually quite easy.
    1. The calculator should be powered and be "on" and the removable plastic should be affixed in its normal position (from this the paper emerges and the plastic is serrated to tear the paper when it comes out).
    2. Take the roll of paper and put it on the spindle with the paper rolling toward you from under. Take the leading edge of the paper and physically lead it into the horizontal slot in the back of the calculator, and press the "arrow-up" button (on the upper left of the board) repeatedly until it catches.
    For some reason, Canon does not make the manual available on line.
    Jul 06, 2009 | Canon P23-DHIII Calculator
    How to use the key to unlock the spindles to replace toilet paper
    On the B-2740...located at the end of each spindle (roller) there is a small hole where you insert a special key (bobkey) or a bobbie pin and depress the locking mechanism. This will release the spindles.
    May 17, 2009 | Bobrick B-2740 Classic Series...
    Cannot load new paper roll into the calculator so it catches
    Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
    When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
    To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
    Then, slide the paper roll onto the feeder arm and you're in business.
    Apr 09, 2009 | Sharp EL-1801C Calculator
    I ran out of paper and purchased a new roll of paper. I do not know how to install the new roll of paper.
    Just drop in, the paper needs to come toward you from the bottom and just past the paper cover once closed. If you have a paper roll spindle, insert and line up with the spindle guides on the machine.
    Mar 20, 2009 | VeriFone Omni 3200 Printer
    Xerox WorkCentre XD100 All-In-One Laser Printer Logo
    67 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
