Question about Mitsubishi VS-50603 50" Rear Projection Television
How do i stop the tv guide plus from loading?
My tv has been loading the TV guide plus for over 24 hours and i am not able to get into the menu to attempt to stop it it just saying to turn it off while it is installing it. However i never initiated the tv guide to be installed.
  • shythegoddes Apr 16, 2009
    my tv says (binstalling guide plus data now turn tv off during installation home to delay cancel to abort) i been trying to hit cancel an nothing will work.
When this has happened to me in the past; if I remember correctly I hit home, stop, cancel, etc any of those gets it to send me the banner that if I stop is not going to CANCEL loading!!! I'm thinking YEAH!!! and then I select the prompt to cancel. I then hit menu again, to cancel and I believe I select home...Now perhaps you think I SOUND a bit "iffy" it would be true; seeing how it has been at least 3 months since it has happened and I sure not going to go and hit that ****** to walk you thru it(he he) sorry but I know you know how it is!!! GOOD LUCK DON'T GIVE UP AND DO YOUR BEST TO NEVER HIT THAT TVGUIDE+ AGAIN (i have many times and its always a pain in my brain)
now get her done!
Posted on Mar 05, 2009
Tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Feb 23, 2010 | Toshiba 42HL196 42 in. LCD HDTV
Guide plus stopped working on my rca tv
Can you please inform us the brand and model of your unit so we can help you better...
Sep 28, 2008 | Televison & Video
TV guide abruptly stopped receiving information
Off-Air reception (Antenna) of TV Guide comes from a supplier called Rovi (formally known as Macrovision, Gemstar). They have supplied your local CBS affiliate with a TV Guide application known as SCTE 127 or VBI in MPEG. Follow these steps until you have found a solution to the TV Guide - No Information Available.
1. Check to see if your local CBS station is coming in clearly not tiling.
2. Reset your TV Guide through your TV Guide Menu, for more information copy and paste the link below. (What usually works for me is setting up the guide by putting in 99999 for the zip code then answer all other questions. After it says your TV will receive the guide in 24 hours then setup the guide as you normally would with your zip code).
3. Contact your local CBS affiliate engineer and see if they are having problems with the TV Guide transport stream i.e. SCTE 127 or VBI in MPEG
FYI if you get your service from a Cable TV company they will have to pass this information through their system commonly referred to as Passing PIDS.
Feb 08, 2010 | LG 50PB4D 50 in. Plasma HDTV
When I turn on my internet and TV with the universal remote the Guide Plus menu comes up as well and we can't get out of it without turning the TV off then on again manually. Is there anyway to program the...
1. When you cut on you tv the guide pops up.
2. On the tv remote there is a button that says "menu" hit that and the screen should go away, i just did it myself because i have my tv program with that Jumbo Universal Remote Control and just ran into that problem.
3. How to just program it out of the tv when its cut on all together, im on the hunt for that answer myself.
4. Try going to manufactures website and try trouble shooting for your make and model, that is what i am about to do right now. Cable tv has the guide so i don't need my tv to pop up its guide also.. you now.. good luck
Jan 05, 2009 | RCA 24F512T 24" TV
Guide Plus crashing
This problem is possibly a failure on you digital main pcb. Hoping its not hardware, best thing is to try to totally reset the guide plus. Go into the guide plus menu and find the setting to reset or restart setup. If this does not solve you issue, try hard booting the tv (unplug for 2 minutes) and try again. In quite a few cases, the manufacturer of the tv will have a software upgrade that may fix guide plus issues. Contact your manufacturer for that information
Dec 07, 2008 | Televison & Video
50604 tv is trying to program channels how do i stop it ?
have a look here for your replacement mitsubishi remote:
Nov 26, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Guide plus rca tv how do stop it from coming up when turning on tv
I have a rca tv guide plus that has the back pannel lights on, but is unplugged, what is the problem?
Jan 04, 2008 | Televison & Video
Rca tv f27628
Turn on the TV
using original remote:
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu)
Select option 1 (TV Guide Plus Setup)
Find the MENU, GO BACK and Input button on your remote
Press the MENU Button then immediately:
Press the GO BACK button then immediately:
Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Nov 11, 2007 | RCA F27628 27" TV
TV Guide reset
Try this (with the original remote): Reset TV Guide On Screen
1. Press the TV Guide button
2. Curser up and over to the SETUP menu
3. Select Change system settings (highlight only)
4. Enter the following numbers … 753159852 (setup mode)
5. Enter the following numbers … 653274147 (reset mode)
It will take some time to get the guide downloaded, but it works.
Oct 06, 2006 | Pioneer DVR-633H-S
Televison & Video Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
