Question about Kenmore Washing Machines
The timer on our Series 80 top loading washer is not working.
I would like to replace the timer but I can not find instructions for doing so.
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Nelson water timer instructions
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Link has all sprinkler timer manuals available online 2012.
Probably does not include older timers since manufacturers post recent manuals, with expectation that today's sprinkler timers do not last long. Except for Intermatic 120V-240V sprinkler timers that are made to last decades and have replacement parts.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment as needed.
Jun 06, 2013 | Hardware & Accessories
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
Describe your INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR Problem -- I lost my instructions. I'm surprised they are so hard to find on line. Where can I find out how to program the timer?
1) Thank you for the model number.
Question posted under oval-shaped Woods 59112 timer.
This timer has minimum 5 different product numbers, and has also been misidentified by sellers as 59203, plus Westinghouse has two similar oval timers with 2 additional product numbers.
Open following links to identify timer and download possible manual:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Typically: Always come to fixya when searching for a manual, and describe product and include product number for best possible result.
3) When searching for on-line manuals:
a) put quotation marks on search parameter: For example "59112 manual" or "59112 timer manual" or "59112 timer"
b) do a google image-search for 59112 timer
c) I usually image-search first to identify product. And then google search with instruction .pdf
So search would be: 59112 timer manual .pdf -or- 59112 timer instruction .pdf
4) Generally, except for industrial timers that have replacement PC boards, there are no repairs for defective timers.
5) Plug-in digital timers have replaceable battery, or have rechargeable battery.
Last step troubleshoot is to replace battery and reset timer.
The rechargeable battery is not replaceable
If timer function is not restored afterward, then timer has gone bad.
6) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 09, 2011 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Timer will not trip. do I have wrong tripper?
Unknown if this is about setting up new timer, or about timer that worked before and trippers need replacement.
Open following link for instructions in troubleshoot format, and links to replacement trippers and tips for having power pack to last longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 11, 2011 | Malibu Intermatic Inc. ML300RTW 300-Watt...
How do I set the time for the clock on the timer. How do I st the timer? I lost the instruction page.
Open following links to identify timer and read instructions.
If this is not your timer, or instructions are in error, then add a comment with clear description of timer for possible help.
http://waterheatertimer.org/pdf/Sunbeam-61048-countdown-timer.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
Jul 25, 2011 | Sunbeam 6 Robinson Home Digital Timer
I need basic operating instructions how to set timer and how to override the timer
Open following link for T1906 wiring and programming instructions, replacement part numbers, and copy of manual:
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
Open following link for troubleshoot checklist:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment for more help.
Upvote the help.
Jun 07, 2011 | Intermatic Timer T1906 24 Hour Dial...
We replaced the battery for our Intermatic Rain Tight Outdoor 7 day digital timer MODEL HB71R70 but the instructions to reset the timer have been misplaced. Could you please supply us with step by step...
Hi Maggie.
Intermatic no longer makes HB71 timer, and I cannot find instructions for the timer.
Intermatic website is offline on weekends starting March 2011, but I have searched the site numerous times over past year and they do not post that manual.
However I might be able to piece together steps if you add a comment and include in-focus photo of timer and buttons. Also include anything you can remember about setting the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
My understanding so far is that this timer has 2 slide buttons, and several push buttons.
Typically slide button timers require both slide buttons to be in one position for setting timer, and another position for programming timer, and another position for operating timer. The complicated steps are why timer has been replaced with newer models with sleeker programming.
If you do not want to bother sending photograph, or working on the problem, then buy another outdoor timer for 20$
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://www.homedepot.com/Electrical-Dimmers-Switches-Timers/h_d1/N-5yc1vZ1xg8Zbm2d/R-100685861/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Apr 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I had a timer model EJ341C many years ago, it was broken down. I went a store and the salesman said the new model EJ351C is the substitute. My questions to you is (1) Are these two models pretty much the...
Hi Henry,
Intermatic EJ351 is sold today to replace earlier models.
EJ351 is very popular 24-hour ez-set timer with simple wiring.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Connect wires inside box to either timer wire.
Red indicator light is helpful when setting timer program.
Add a comment if instructions are confusing, and say what part of manual does not make sense.
Apr 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Washing Machines Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
