Question about Ariens Garden
Oil for ariens 642 snowblower
What kind of oil does the Ariens 642 snowblower take?
  • 70 Answers
SOURCE: Ariens 926LE snowblower won't engage
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Posted on Dec 22, 2008
  • 21 Answers
SOURCE: need a copy of owners manual for ariens st5+2
try tradebit.com they should have what you need
Posted on Jul 29, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
rwvanlue
  • 486 Answers
SOURCE: How much oil is in an Ariens 5 hp snowblower ?
5 hp should have 20 oz.
When checking,
1) fill the oil to top of threads (if the inspection cap is threaded into the side of the block close to the bottom)
2) if it has a dipstick, wipe the stick as you remove it, re-insert *do not screw it down, just allow it to set on top of dipstick housing.
*note: you cannot overfill unit on an inspection cap
*** you CAN overfill on a dipstick. Any more than 22-24 oz, the engine will blow it out the valve cover breather hole.
Posted on Nov 12, 2009
Testimonial: "Quick,accurate response --- thanks"
rwvanlue
  • 486 Answers
SOURCE: I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
I didn't realize that my Ariens 522 2 cycle snowblower is a oil/gas mix. I filled my tank full with just gas and no oil. Can i just add in oil and manually mix it?
Yes, you can. I thought it was a chain saw, but you can shake a snowblower :>) Put the oil in stir vigorously with a spoon.
I changed the category.
Dec 12, 2016 | Garden
Why do I have hard time starting my ariens snowblower when cold?
does it have a primer bulb been seeing a lot of the bulbs with cracks
Feb 17, 2015 | Ariens Deluxe 28 Model 921022 St28le 2...
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
Ariens 624e oil type
Engine- 30w summer
5w-30 winter
Gear case L2 lube, ariens part no. 00008000
Dec 09, 2013 | Garden
How do I change ariens snowblower belts
Oct 12, 2009 | Ariens Garden
Need manual
my ariens mower won't go forwards or backwards
Feb 04, 2009 | Ariens Garden
Garden Logo
206 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
