Question about Refrigerators
I bought kenmore refrigerator in 2003. It's a top freezer refrigerator. Lately I'm finding water on top and bottom shelves. What can be done
  • Story54 Mar 13, 2009
    Also have interior moisture buildup, gaskets seem fine.
  • 400 Answers
Check your door gaskets are sealing properly.
Posted on Mar 05, 2009
  • Shane Seaman Mar 05, 2009
Water is collecting at the bottom of the refrigerator under the drawers
You may have a bad gasket, which is allowing moisture laden air to be sucked into the refrigerator. The moisture then condenses on the walls / shelving, and finds its way to the bottom.
Feb 13, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator 106.72206201 - accumulating ice and water
Probably a clogged drain line in the freezer. Unplug it for 2 days and leave it open. Reset controls to 3 and C or factory settings clean the coils on the bottom outside with a vacuum and a brush and restart the fridge.
Sep 11, 2009 | Kenmore Refrigerators
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmroe64802 refrigerator not cooling
You are probably storing items too close to the top shelf of the freezer, stopping circulation.
May 01, 2009 | Kenmore 64802 Top Freezer Refrigerator
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr
Apr 28, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 63712
if there is water on the top shelves in the fresh food section you may have a drain problem when the freezer defrosts. one other possibility is there is a air leak somewhere could be a bad door seal. when warm air enters it will cause condensation and water will drip on the shelves.I suspect it might be comming from the freezer though. a easy way to check is to remove the back panel in the freezer and check for ice in the drain pan. if there is a blockage use a hair drier to melt the ice and hot water to clear the drain. let me know if this helped you solve your problem Good luck
Aug 02, 2007 | Kenmore 63712 Top Freezer Refrigerator
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
