Question about Jenn-Air JGS8850ADS Gas Kitchen Range
Back Left Burner clicks
Have a Jenn-Air JGS88850ADS , back left burner click when the flame is set on low. All other bruners work fine. How can I correct this problem
    Brigadier General:
  • 8,619 Answers
Hi!
Please use a blower or hair dryer and blow out any moisture on the back burner knob. This happens when moisture enters the knob area. Moisture shorts the connections and thus, its clicking continuosly.
Also, check for the electrical connections.
Please ask for further clarifications.
Please rate this solution.
Thanks
Rylee
Posted on Mar 02, 2009
The center burner knob on my jenn-air grill gets hot, the far left knob is off, and the outside cover is showing burning residue
From what you have described, it sounds like the offending burner tube is partially clogged and causing the burner flames for back fire and heat the control panel. To solve this, you will need to remove the burner and clean it and it's venturi valve thoroughly. You can accomplish this with a soft bristle brash grill brush or an old tooth brush.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Sep 04, 2011 | Jenn-Air Grilling
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Oven burner seems to have low flame
Check voltage to gas valve in the back of the boiler compartment. It is way in the back on the left hand side, turn on the top burners. If you do not get any volts or only 1 to 5 volts you will need to replace, It is supposed to have 24 volts to operate correctly
Feb 09, 2009 | Jenn-Air JGS8850AD Gas Kitchen Range
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JGS8850ADS Gas Kitchen Range Logo
183 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
