Question about Pitney Bowes Office Equipment & Supplies
Pitney Bowes FD40 folder Stacker Error
Each time I turn on the FD40 the display reads Stacker Error press Enter to reset. I have tried Pressing Enter. I have also tried removing the Fold Plate and turning the stacker motor gear to move the stacker to the other end. Each time it is turned on it reads Stacker Error. Please Help.
  • 9 Answers
SOURCE: Pitney Bowes FD40 Folder Top Cover
did you fixed your problem with the folding machine??
Posted on Mar 18, 2010
Pitney Bowes FD40 error top cover open
Locate the top cover switch that is apparent stuck in the open position. Fix or bypass it.
Oct 20, 2016 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes 1530 Memory Full
1. Press FEATURE
2. Press 9 9
3. Press * * * 1 (this is the service passcode)
4. PressYES
press 095
press yes
press stop to exit
Sep 16, 2009 | Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
457 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Paul King
Paul King
richie46
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
