Question about Troy-Bilt Garden
Snow blower auger sucked up welcome mat and is jammed...how do i remove the mat when auger will not turn?
2 Suggested Answers
  • 2248 Answers
SOURCE: I have a welcome mat jammed in the auger, need to remove auger
Can you take a sharp knife and cut the mat loose? You might have a hard job taking the auger apart with something wedged in it. Even if you use a hacksaw blade with out the saw frame. anything to work it loose. pour boiling water on it will make it cut easier if it's rubber.
Posted on Jan 31, 2015
Jan 31, 2015 | Miscellaneous
How to remove the right hand auger from a nova performance snow blower model 629104x31
remove the whole auger from machine and then remove the shear bolts. Slide the auger off shaft
Aug 25, 2014 | Garden
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
Jan 17, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a Troy bilt Storm 9528 snow blower (about 3 years old). This year I am having trouble with the snow discharging. It doesn't seem to take much snow jam it up. At times the auger barely turns when I...
adjust the auger cable so its tight, it most likely got loose. The adjustment is on the back of the machine theres 2 screws just make the auger cable tighter. this should solve your problem
Dec 02, 2010 | Sport & Outdoor - Others
Garden Logo
154 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
