Question about GE Ultrasonic 2.1 Subwoofer Computer Speakers
I just got a Klipsch cs-700 and my subwoofer doesn`t work, I macht the home code to "0" in both (DVD and subwoofer) and nothig, could you help me what can I do to fix it?
  • Anonymous Mar 12, 2009
    klipsch cs-700 subwoofer stopped working.
I never used my 10sw klipsch subwoofer and it's not working.
Check the cone surround - unless it is a rubber butyl surround, the material self destructs in air after about ten years and the speaker will stop woofing.
Apr 05, 2015 | Klipsch Audio Players & Recorders
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
Klipsch Synergy Sub12 Subwoofer Speaker
If it's a new model you should send it back.
If it's not then it sounds like the thing that does all the work has gone. It will be found on a heat sink. Try replacing that.
Jan 25, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Klipsch cs-700
my klipsch cs 700 subwoofer not work
Jul 19, 2012 | Klipsch Audio Players & Recorders
No sound coming from subwoofer
Sure we will help you, but you need to check these,
1.Wiring connection from dvd player to home theater system,
2.Wiring connection of a home theater amplifier to speakers,
3.While playing the Original dvd the 5.1 audio you have to manually enable.
and if you still find any difficult please feel free to contact.
Mar 28, 2009 | Audio Players & Recorders
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
911 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
