Question about Vacuums
Hi, Fitted new paper bag to this cleaner but have 'No' suction. With bag removed no air movement can be felt at outlet(ie bag entry). Have you any suggestions?. Many thanks, John Pessall.
  • 328 Answers
What kind of model is it?
If you have the bag door open just to feel if there is suction it won't work. The machine would have to have its door put back on before suction can be ascertained. In the meantime check the hose that leads into the bag, or main dust channel - it may well be clogged as well as motor filters usually located under the paper bag.
Posted on Mar 06, 2009
How do I put a new bag in my vacuum cleaner
The collar on the replacement paper bag has to be forced onto the outlet as described and illustrated in the replacement instructions printed on the bag.
Jan 19, 2015 | Vacuums
No suction of hoover carpet cleaner
Might be a bad blower/impellar - you must disassemble to check. But most likely the lid on the recovery tank is not installed correctly allowing air (suction) to leak. On most models you can remove the solution recovery tank, turn the unit on and feel for suction where the tank fits onto the base (look for the round, black rubber type seal in the front corner that mates to the round outlet on the underside of the recovery tank.) If there is good suction at this seal, then the problem is an air leak, almost always due to a loose or incorrectly fitted lid on the recovery tank. Also, if you have a detachable insert (for attachments) on the front of the recovery tank, check that the insert is installed properly. If this is reversed it will not provide suction.
Sep 02, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Telios 1600
There are two main filter outlets on the Telios. One behind the dust bag inside the vacuum (white felt with a black carbon layer usually - or a HEPA paper cartridge that slides right in at the back, though the HEPA filter cuts the suction power considerably, so just get the carbon type with the white felt if you can). The main motor filter at the top is between the power pedal and cord rewind. This is usually a 7 layer microfilter, but you can use any filter such as universal cut to fit types or even a Dyson DC01 filter that has been cut to size.
Apr 30, 2014 | Vacuums
The suction seems so strong on the floor that it is suddenly hard to push. Don't notice anything thing that would actually lift it off the ground making the suction not so air tight. I have check the...
I'm sorry to hear you're having difficulty using your DC24 on this particular flooring. The cleaner head is designed to adjust automatically to suit the surface being cleaned, and the cleaner's powerful suction causes the soleplate to seal closely with the flooring for high pick-up of dirt and debris. You may find on certain floor types that this makes the cleaner feel a little heavy to push.
Reassuringly, it sounds as if your cleaner is working correctly - however, if you wish to discuss your issue further with one of our experts, please get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Jul 17, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Vacuums Logo
119 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
