After starting projector, lamp flashes on and off and I can not get to any of the projector menus.
  • 2,237 Answers
Check the lamp for bulges, black spots and fogging. replace if necessary. if you have a dlp projector, check the colorwheel. otherwise, repace the ballast.
Posted on Dec 23, 2009
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Lamp flashing, hd72 projector
In most projector menus there will be an option to reset the lamp timer, it's usually under the "settings" area of the menu. Try resetting the lamp timer and the light should stop flashing.
Jan 17, 2010 | Optoma HD70 DLP Projector
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Sharp XG-E650UB LCD Projector won't display picture.
it only takes up to a 640x480 resolution. it is a very antiquated projector.
Aug 10, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
Lamp indicator flashes three times even with new lamp.
Check your manuel for Lamp counter reset facility , lamps sometimes will not retsrat untill this is done ... Regards Vortash
May 05, 2009 | Office Equipment & Supplies
PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
481 people viewed this question
jasbo
jasbo
