Question about Proscan 42LA30H 42 in. LCD Television
3 light x-lines across TV screen
I just bought and installed a 47 inch new ProScan TV. About 1/3 the way down 3 light lines of x"s are barely visible across the screen. I sent in my warranty card but don't know who to call for assistance. Thanks for your help !
Frank A
  • 362 Answers
Proscan is now owned by RCA, you will need to call the number below and explain the warranty info.
If your concern is urgent, we can be reached by phone at 877-794-7977. Our hours are 8AM - 8PM Monday - Friday EST and 10AM - 7PM EST on weekends.
Let me know if I can assist further. Please rate this solution.
Lone99star
Posted on Mar 02, 2009
  • 463 Answers
From elsewhere on the web:
"Proscan used to be the RCA high-end trademark; RCA (at least the TVs) was purchased by Thomson; they leased the proscan name to a Korean outfit that has the TVs made in China.
I've never owned a Proscan (post RCA)... but the internet buzz is that they are of inferior quality and that it's virtually impossible to get support in the USA. I would qualify that: Costco is selling Proscan TVs; they extend the warranty by one year (to two years); and if you have a problem, ya got Costco behind you. So I guess unless you buy one at Costco, you should pass"
Perhaps you need to contact the entity at which you purchased the television.
Proscan 42 in tv....has a very thin line about 4 inches from the bottom of the screen. we had the tv for almost 3 years. this just started last night. can it be fixed?
Anything can be fixed, short of it being totally destroyed. The question is can it be fixed in a cost-effective manner? Today's TV sets are manufactured for a three-year lifespan....regardless of what the manufacturers say. They are made with minimal-tolerance components, and are designed to fail in the 2-4 year range. Most make that, some don't even get out of warranty. The manufacturers take the risk because it is more profitable for them to make some warranty repairs in order to get the repeat buyer in 3 years instead of 10. If you got 3 years out of you set you did well. Some try to repair the sets themselves; some are successful, many are not. These devices are delicate and often in the process of fixing one thing, something else gets broken. You can try for repairs, but you are most likely better off buying new, and consider this when buying.....look for features you want NOW and not in the future, since by the time those feature are needed, you will be once again in the market for a new set. One additional piece of advice; to help these new devices last longer, buy and install a UPS to protect them from voltage variations and power surges. Surge suppressors alone can help, but they don't respond to voltage variations that often occur in electrical service. These are often the killers on these devices.
Mar 19, 2016 | Proscan Televison & Video
Proscan 7 inch tablet keeps freezing
My proscan tablet is keep freezing and lines are coming across the screen. What can I do
Dec 28, 2013 | Proscan 7-Inch Android Internet Tablet,...
I have a line at the bottom of the screen about an inch up. How can I get rid of it without spending more than the TV is worth.
A reboot or factory reset if possible will not help with that issue---bad connection somewhere or bad display panel (screen unit).
Nov 08, 2012 | Proscan 47LB45H 47 in. LCD TV
My tv has white lines that run up and down across whole screen. it has like 4 lines then a inch space then 4 lines and a 3 inch space My tv is a SAMSUNG HL R5667W
Power supply board, Look for bad capacitors they will be vented or puffed up on Top.
Encompass parts has whatever you need for this model
1-800-638-3328
Mar 02, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I have a PT-47WX53 that has one vertical bar down the middle of the screen. Barely visible in a purple hue and about 3-4 inches wide. I'm looking for some suggestions. Thanks
A few simple things you may try. Under your menu on the tv look for convergence or it also may be under setup. Run the convergence setup and follow the on screen instructions. If the tv fails to converge while in setup you may need to replace some things however the parts are very very cheap. If your convergence setup works and you still have a bad picture, and or both, meaning the tv's convergence wont align then you may need 1 or 2 IC's and maybe need to change your coolant in the tv's RGB lens...all can be done with little experience and for under 50 bucks. I can give more detail if needed.
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Dec 27, 2008 | Proscan Televison & Video
Line across screen
I have the same problem with my 42 in. The line started to show up randomly about 1 month after i got my tv. The line isn't a line of dead pixels since when i change the aspect ratio or the tv the line moves up or down. I called sharp about the problem and they said it had something to do with my computer but i don't think that can explain why the problem shows up on all my tv inputs.
Dec 17, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Screen on rca tv compressed into 2 inch line in middle
The 20F530T uses the relatively newer ITC008 chassis. If the picture collapses down and only a small bright line is visible, it means that your vertical output IC has stopped working correctly. This could be due to a defective IC, cracked solder joints on the IC or the power supply that feeds it. The IC should be replaced or resoldered and/or the vertical power supply restored by an experienced tech familiar with the new line of RCA TV's.
Aug 10, 2007 | RCA 20F530T 20" TV
Proscan 42LA30H 42 in. LCD Television Logo
201 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
