Question about Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor
Lcd monitor power light flashing with no img. seems 2 be frozen
I have a Samsung Syncmaster 204b lcd monitor. about 4 months ago if i shut the monitor off for 5 minutes or more and went to start it up the light would be very dim and after about 2 minutes it would get a little brighter, then kinda flicker then 2 minutes later it would finally go back on completely. and then all of a sudden 2 days ago, the screen went entirely black. everythings in correct nuthin loose or broken.
so now when i try to turn it on, the power light flashes forever and if i press the auto set button or the power button, nuthin happens. to turn it off i need to flip the switch under the monitor.
after fiddeling it for a while turning it on and off and all this other stuff it would start to come back on. i would see the little whte box on the top left saying digital then analog then digital then after 10 minutes letting it sit, it comes back on. so not sure at all what could be the problem. i use my computer alot, and dont have a job so i cant just get a new 1. hopefully its sumthing cheap that can be replaced. maybe the back light?
  • Anonymous Mar 02, 2009
    na its the power light on the frame of the screen, the screens completely black
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Posted on Sep 03, 2009
I have a smasung 190S and there is no picure for the past 5 months, but the light is flashing yellow all the time no matter which buttons I push or what I do, unplug the monitor connections or unplug the power source. Any suggestions before I throw it in the trash?
Posted on Aug 16, 2011
  • 748 Answers
If the light you're talking about is the light to the screen then the mecury bulb or the converter are going bad. There's not many people out there willing to replace mecury bulbs. Check around to find one.
Posted on Mar 02, 2009
Flashing power light
The power supply inverter board usually ends up with one or two bad capacitors "sometimes puff at top" causing monitor not to power up.
Mar 17, 2012 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
SyncMaster 204 Samsung monitor has no power
Have you tried to plug it in else where?
If you did and still same problem then from what you said I was hopping that it wouldn't be your problem, but you will need a new monitor.
Mark
Mar 29, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
LCD Monitor SAMSUNG Syncmaster 172x
change the potentiometre(three broches) and adjust it.
you find it near circuits which switch on the lampes (card has smalls tranformers)
good luck,Mustapha(Casablanca,
Morocco)
Apr 08, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Planar PL1910M (Black) 19 in. Flat Panel LCD Monitor Logo
1,958 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
