Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
When i plug in hd wires for a ps 3 the picture has horizontal lines that go up and down
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiwhen i plug in hd wires for a ps 3 the picture has - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
of a set that needs the fluid cwhen i plug in hd wires for a ps 3 the picture has - 2c07611.png/>
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Posted on Mar 15, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Dec 20, 2015 | Televison & Video
Security cameras mon itor is blank
Try adjusting the iris settings down. Your camera's auto iris function may be broken, or the software control for the auto iris might need to be fixed.
Jan 04, 2014 | Computers & Internet
Vertical line
There is only two possibilities for this fault. As far as horizontal output section is concerned, it is working well, otherwise you will not get any screen illumination. Here up to horizontal output section is Ok. Then come the first possibility, the connection to the deflection yoke [the coil fitted on the neck of the picture tube] and it sconnection related. If this connection is open or loose contacted, there will be no horizontal scanning pulse reach to the coil; resulting a thin vertical lin through the middle of the screen. The second possibility is the deflection yoke, the coil said above is open. It is a very rare case, adn the possibility is only 2% or so. Your Tv must have the first said faut I thinks.
Open your tV, and follow th wires [usually 4 of them] from the delection yoke said above, and you will reaach to a point on the main board where they are socketed to a point. ust pull out and replugh that socket 3 or more times. If there is any loose contact, this process will retify it. Also check for any loose soldering point at the solder side of these four pins, and there is a capacitor that bypasses the horizontal scanning pulse to the deflection coil, check the soldering of its terminals for any loose. There are no other possibility in Sony sets to show this type of fault. OK.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Horizontal lines
Try to reset ur camera. otherwise u should contact to service center. I think its hardware problem.
Mar 27, 2010 | Samsung S630 Digital Camera
Ps 3 gets power but it wont get a pic on tv, it was used on a hd tv but i dont have a hd tv, wats up with it
try plugging it in with another cable (if ur using av try hdmi or other way round) if it works you can change it to work with the lead you want under picture or screen settings*
*cant remember which it is
Dec 12, 2009 | Sony Video Game Consoles & Games
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Horizontal Lines Moving Up Screen
Hi Folks,
What you are describing sounds like grounding or EMI issues with your AC power. If the lines or bars are soft and moving up the screen, typically there is an issue with the ground at the AC plug, or dirty AC from another device in the house (usually the refrigerator). Make sure the TV and PS 3 are on the same circuit (two wall outlets in the same room are usually NOT the same circuit). Check the outlets wiring to insure it's correct. You can do this with a Snap-It circuit tester (about $6.00). Many older buildings might not have the ground wiring properly installed or a previous owner/tenant wired something "wrong". You can get an EMI (electro-mechanical interference) filter at places like Radio Shack. You can put them on the PS 3 and the TV, but I would try one on the fridge first-make sure it can handle the refridgerator's power requirements.
Sep 24, 2008 | Sony Playstation 3 (PS3) Console
Hd to normal tv problems
i had the same problem, but the reset worked for me, hold down the power button until u hear the "beep"
Apr 26, 2008 | Sony Playstation 3 (PS3) Console
WD My Book 500g HD error. Turns off when USB is plugged in
Check the USB port on your computer. It's very likely that the problem is there. On my computer USB ports stop working sometimes and the HD does exactly that. HOwever, when i restart the computer, everything works fine.
Mar 30, 2008 | Western Digital My Book Premium ES...
Scrambled picture horizontally
Is this HD on 4 and 5 then it will do it if you don't have a HD signal.
Nov 26, 2007 | Philips 55PP9701 55" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
