Question about Malber WD1000 Front Load Washer/Dryer
Need service for Malber 1000 heating element..
I have a Malber 1000 washer/dryer combo unit and the heating element for the drying cycle stopped working. The machine still spins and condensates through the cycle, but with no heat. I live in Haverhill Massachusetts and am having trouble locating a repairman/service for a Malber. Any suggestions for an affordable fix and/or how to get a local service call? I know it most likely needs a heating element replaced, but without parts locally available, and someone knowledgeable in Malber repair to fix it, I don't know what I can do. I've tried calling the 718-767-7396 # in NY but haven't been able to get through..
  • jrc2127 Apr 01, 2009
    I think it's the same problem: the heating element clearly isn't working, but the timer for the dryer also seems involved. it sticks right around the 120' mark, and although you can force it (I've only done it once), and then the timer dial will move (if you don't force it past that point, it won't), it never shuts itself off and the heating element never goes on. I also haven't been able to get through to that NY number, though I've had good luck w/ them in the past (I'm in Brooklyn).
  • 29 Answers
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
Posted on Mar 11, 2009
  • 1 more comment
  • ghousman Sep 26, 2010
    We need to replace our door latch. Can we do it ourselves? Get the part at Malber or do we need a new door?
  • Gearmeister Oct 03, 2010
    Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear).
    Once you've received your new latch assy (about $20):
    Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery.
    Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around.
    Remove front "ring" and set aside.
    Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back.
    Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes).
    Replace 2 screws. Test latch with door open - is it working? Try closing door. All good?
    Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around.
    Test that door latch still operates smoothly and that door latches shut properly.
    FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to.
    Good luck and God Bless ...
  • JoJoNoLow Sep 09, 2011
    Actually the problem is likely to be the heating element. Suds can get up into the area where the heating element is and corrode it over time. I took Mike's advice and checked the thermostat first--the easiest fix--but it worked fine. The heating element though was completely corroded through.
SOURCE:
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
NO Heat ,when in Drying Cycle. Drying cycle works, but with no heat.Does not dry clothes.
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things: Mainly Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 08, 2010 | Malber WD1000 Front Load Washer/Dryer
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
Aug 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
Jul 21, 2008 | Malber WD1000 Front Load Washer/Dryer
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (danfrogel@yahoo.com)
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
1,296 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Android Man
Android Man
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
