Question about Tomtom One XL GPS Receiver
Tomtom problem with solar glass
I have an Audi S8 fitted with solar glass therefore my tom tom does not work even with the external aerial?
  • 463 Answers
Is the external aerial outside of the passenger compartment, or somply up on the dash? If the external aerial is on the roof and hooked to the display unit properly and still does not acuire a signal (assuming you're not parked in a lead-lined garage), then something else is afoot.
Posted on Mar 02, 2009
Tom Tom doesn't Work inside the car
Metal blocks signals. If you are putting the TomTom on the dash, and there’s still a weak signal, then there’s metals (or some impurities) in the windshield interfering with the signal.
Try having it held near the rolled down window on the passenger side.
If this helps, then you might want to find out if your model has available an external antenna!
https://us.support.tomtom.com/app/answers/detail/a_id/4973
Sep 23, 2017 | Mercedes-Benz E-Class Cars & Trucks
The Navigation system in my 2002 audi S8 is "lost" and does not seem to be getting a lock on any satellites. Any ideas what to check?
Could it be the aerial somewhere ?? i have no idea at all other than the aerial ,i always stop to ask directions or go into the local cafe and have a coffee and ask where is somewhere .But these sort of faults might need the correct dealer software to locate the fault as yes the aerial is the most obvious but it could have a failed tuner reception chip ?'
Apr 24, 2011 | 2002 Audi S8
Windows 7 64 bit does not recognise my Tomtom go 630 on Compaq 610 laptop - have latest "my tomtom", Video convertor for Tomtom & Tomtom home 2
Windows 7 is a new operating system, it does not support so many applications, softwares and files, Therefore, not being able to use your tom tom on your windows 7 should not come as a surprise to you as windows 7 does not support so many kind of softwares.
Try your tom tom video converter on another operating system and am very certain it will work there, except if there is a problem with the converter itself. Try it out on windows vista, windows XP etc.
Best regards
Dec 29, 2010 | Tomtom Go 630 GPS Receiver
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
No signal on my gps tomtomxl330'
I have the same problem, I drive the Audi A8 which has a UV filter built into the glass, it blocks the signal, the only way around it is to use an external aerial, only £5 on eBay
Hope this helps
Mar 14, 2010 | Tomtom XL 330 Car GPS Receiver
My TomTom one no longer sees the aerial when it is connected. Is this a hardware fault or a service/subscritption issue?
Try resetting the device. You do this by sticking a paperclip into the small hole on the bottom of the receiver (check your users' manual for the details).
This may be caused by unplugging the aerial before shutting off the navigator.
Nov 11, 2009 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Loosing signal
I'm afraid it happens (particularly in towns and cities) The GPS needs clear line of sight to at least 3 satellites. On cloudy days it can reduce the signal. An External aerial might help in a car (particularly with tinted glass)
Aug 21, 2009 | Tomtom GPS
5 MPH DIFFERENCE BETWEEN CAR AND TOMTOM GO 530
The TomTom is being tracked by upto 11 satellites, therefore the speed on your TomTom is correct. Generally a speedo in a car is around 5-10% inacurate.
Jun 15, 2009 | Tomtom GO 720 GPS Receiver
Tomtom traffic reciever
You can purchase a traffic receiver through Tom Tom here:
http://www.tomtom.com/services/service.php?id=44
or here:
http://www.tomtom.com/products/accessories/accessory.php?ID=804
The device depends on external transmitters broadcasting traffic data. I'm not certain that the service is even available in South Africa. Please check to make sure you can use it before you purchase anything.
Jan 01, 2009 | Tomtom Traffic Receiver for Select GO GPS...
Tomtom One XL GPS Receiver Logo
76 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
