Question about Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range
I have Whirlpool error codes E-1 and F-5; My range door is locked. Please help.
  • 15,935 Answers
Here are 3 Service manuals for your oven.
The E1 F5 is a door latch error.
SEE MORE ABOUT THE PROBLEM HERE
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused. You should disconnect power again for 15 seconds and reconnect and see if that helps. If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display. This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control. Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 02, 2009
My WhirlpoolModel SF379LEK display shows an FS, E1 code and beeps. Any Ideas? Thanks for any help
Hi
Error code F5-E1 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 29, 2011 | Whirlpool RF378 Electric Kitchen Range
Whirlpool Electric Range Model # RF369LXPB. Self cleaning function does not work. A code displays after self cleaning function has been on for about 3 minutes. The code is F5EO. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Whirlpool RF369LXPQ Electric Kitchen Range
My whirlpool washer cabrio is displaying dl and i need to do laundry lol please help
bad door lock you can trip the door lock by placing a large magnet in the front of the lid which will trick the unit to opening the lock if you have any further questions message me back and beware of error 50 and 51 in the cabrio they are whirlpools problem model in which they werent designed well or engineered well either as to the rps sensor causing issues with these two error codes I await your reply if you have any further questions and please remember to rank when our chat has fully concluded it allows me to help others in similar situations in the future most likely you will have to order a new door lock assembly due to this error Thanks again Rick
Apr 24, 2011 | Whirlpool Kitchen Ranges
Why won't the oven door lock to start the self cleaning? The door appears to be shut all the way. After hit start, this code appears E1 F5
According to the Whirlpool website, the self-cleaning latch may be interfering with the door, though this would be indicated by an "E0 F5" error code. If that's the case, Whirlpool recommends the following:
1) Press "Stop/Clear" to clear your display.
2) According to Whirlpool, there should be a door switch plunger in the upper right corner of the oven front. Press and hold this so that the door latch will unlock.
However, if it is indeed "E1 F5" (or any other number with those letters in the code), Whirlpool recommends calling an appliance technician.
http://whirlpool.custhelp.com/app/answers/detail/a_id/319/kw/error%20code
Feb 28, 2011 | Whirlpool Kitchen Ranges
Whirlpool gas range error code f2
Hi sauerteig_j,
Whirlpool F2 error code indicates that oven temperature is too high. And to fix this problem:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just have your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Feb 08, 2011 | Whirlpool GS475LEKS Gas Kitchen Range
We have a whirlpool glass top range.auto clean will not work. get an error code e-1 f-5. door doesn't lock and no heat. range is a style 2 model
Check door latch switch. located at the rear of the range. remove back panel. I believe that the assembly includes the lock motor, with micro switch
Jan 15, 2010 | Kitchen Ranges
F5 error
F5
Board failure
Need to Replace control board (also called ERC or clock).
If you need to open the door, it can only be done by dismantling it.Do not apply force on the door.
Here is the manual link, in case you need one.Am sorry but whirlpool manuals are mostly not free online.and this is one of the cases
click here for manual
please do post further comments if you need any more help.Am glad to help you out.
Jan 13, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Whirlpool GR773LXSS - Stainless Steel Electric Kitchen Range Logo
229 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
