Question about Magic Chef CAV2000AWW Top Load Washer
Washer will not operate in cold water
And also shuts off when it reaches rince cycle
  • 464 Answers
Sounds like the water inlet valve solenoid is burnt out on the cold side, hot side is ok. if you have the machine set for a cold water rinse, and the solenoid is burnt out it is calling for cold water and it will not come into the machine. change the water valve.
Posted on Oct 11, 2009
Hi...my washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't agitate
Hiya,
these noices are often caused by a water issue the rince cycle is a cold water intack so i would surgest turning of the cold water at the mains or shut off valve then disconnect your cold intack hose & check for any clogging it could be a build up of lime scale or lint & the simple removal & cleaning of this hose could fix your problem.. alternativly ensure the cold water supply is turned to the on position to allow the water trough to rince
Hope this helps
Apr 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
Jan 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
I have a Kenmore washer. the water temp switches by itself.
IM NOT SURE HOW YOUR WASHER IS SET UP ON TEMP SETTINGS BUT-- THE RINCE CYCLE IS ALWAYS COLD RINCE
Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
Hot water use on a cold /cold cycle
I bleive hot water in introducted @ begaining of cyle to disolve deterant call whirlpool 800 number .
Oct 26, 2009 | Kenmore 43142 Front Load Washer
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    L g steam washer front load
    The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
    after water is supplied or it does not reach the preset water
    level within 25 minutes.
    I suggest you
    Check the screens in the water inlet valve for blockage
    Feb 18, 2008 | LG WM2688H Front Load Washer
    Magic Chef CAV2000AWW Top Load Washer Logo
    69 people viewed this question
    Top Magic Chef Washing Machines Experts
    Robert Smith
    Robert Smith
    Craig Hill
    Chen Dorot
    Chen Dorot
    Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
