Water Leak Top Load Maytag Washing Machine
The water leaks out in the area where the top of the washing machine and the body meet on the left side while filling to wash.
  • 70 Answers
You have a leaking "injector sleeve". you need to remove the 2 screws that hold on the front panel ( they are at the bottom) once you remove them, pull the panel outwards, towards your knees. it will release. on both sides in the top you have 2 bolts, remove them, it think they are 3/8ths. on the left if you have a bleach dispenser, remove that hose before you lift the lid. Once the lid is up you will see the injector area on the top left at the side. Hope that helps
Posted on Mar 03, 2009
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
When water filling before cycle starts, leaking coming below top lid of overall machine on left side only. however, when testing using the rinse cycle, no leaking
I had this problem with my old Maytag (top-load) - it was the injector - an assembly mounted on the top left of the machine - a $10 fix (about $36 for the entire assembly) and the problem disappeared!_906.jpg
Jan 20, 2011 | Maytag LAT2600A Top Load Washer
We have a Maytag top-loader model A482 which is probably 25 years old. I found water on the floor under the machine when the last load finished washing. What's the first place to look for the leak? I'm...
The most common thing that will cause a leak is the tub seal. If the tub seal is leaking water will be comming from the center of the tub where the transmission meets the tub. This page will show how to replace the seal. http://appliance-repair-it.com/Maytag-tub-seal.html
There is also an air-gap that will often leak. If this is the case the water will be comming from the left hand side at the top. The air-gap is in line with the water inlet. This page will tell more http://www.appliance-repair-it.com/Maytag-washer-leaking.html
If they are not the problem you will have to look for a leaking hose or something to that nature.
Sep 28, 2010 | Maytag Washing Machines
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
We have a maytag top lod washing machine model
Hi, the actual drain pump may have a crack on the housing. i would inspect this possible issue just to confirm that the pump structure if well.
Secondly, there may be a slight rupture in the tub seal. you will need to disassemble the tub to get a good look at this possible leak point. this is an uncommon area for leakage but, it is possible that the water is leaking from this area.
Last, i would check the water inlet valves for cracks. this is another uncommon issue but, its worth checking during the inspection.
Jul 10, 2009 | Maytag Washing Machines
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Water leak upon filling at top/cabinet joint
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Feb 23, 2009 | Maytag SAV2555A Top Load Washer
Maytag Washing Machine leak
First plug off the wall. Open up the top by unscrewing screws at the back of machine or wherever. Check out the tubes........
Sep 16, 2007 | Washing Machines
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
