Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
I need to put the lower pieces of my dishwasher back correctly.
I have a Frigidaire dishwasher. I'm not sure the details--we just moved in and I don't have any paperwork, etc. The dishwasher has a stainless look and is pretty simple, in terms of buttons, nobs.
I was cleaning the bottom because it was pretty nasty from sitting water (no one has lived here for almost 9 months). The lower pieces all came out--what looks like a filter screen, the arm that swings around and a little basket that seems to snap in place--and now I'm not sure how to put them back correctly. I've tried finding a picture of the order of those pieces online, but haven't had any luck. I don't know if they need to snap in place or just kind of sit there or what.
Any ideas?
THANKS!!!
  • silkwormdeli Mar 10, 2009
    I can't figure it out, either- have you had any luck?
  • 70 Answers
Just installed a new dishwasher. It will not fill with water. Power on, water on, overfill valve moves free. Water does not go in unit @ all. I can hear pump run.
Hello Tony, I appreciate your inquiry!
I see that your Frigidaire dishwasher is not filling with water and it has just recently been installed. Is your door shut tightly? Also, are there error codes or lights being displayed on the control panel? I would suggest reading back through your installation guide to make sure all the steps were correct. If you continue to have issues with your dishwasher I would recommend reaching out to your manufacturer for proper warranty procedures. -Matt
May 29, 2015 | Frigidaire FFBD2406NW 24" Built In...
Does not drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 21, 2011 | Electrolux Frigidaire Professional Series...
The water is not draining from the bottom of my fdb2810ldc1 dishwasher
Hi
Daniel
Aug 11, 2011 | Frigidaire 24 in. PLD2850 Built-in...
My dishwacher isn't draining and make a noise..
Hi
Daniel
Jul 21, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
Dishwasher stopped in the draining cycle and will not start back up, even after turning thye daqil to start a wash
Hi
Daniel
Jun 15, 2011 | Frigidaire 24 in. FDB221RF Built-in...
Frigidaire dishwashers arms are not moving
Make sure the water inlet valve is fully opening.
Jul 10, 2017 | Frigidaire 24 in. FDB1050RE Built-in...
Upper spray arm broke off
I hope it did not break, only came off. I had the same problem. You have to unscrew the round part from the ceiling of the dishwasher, put the three pieces together, easy, and then screw the whole thing back. No tools needed. Top rack can stay on while working. It helps if the dishwasher is empty. If the threading is good, this should solve the problem.
Mar 06, 2009 | Frigidaire Professional Series 24 in....
Frigidaire FDB751RC fell apart.
call 1-800-803-6775. and they will assist you
Feb 14, 2009 | Frigidaire 24 in. FDB751RC Built-in...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
133 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
