Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer not drying.
Looking at the gas discharge, the igniter lights up ,kicks the gas flame on for a few seconds but then kicks right off! This sequence repeats about every two- four mins. Definetly not drying my clothes.    Also the tumbler is all of a sudden extremely loud. Maybe a worn belt or guide wheel.????
  • 1 more comment
  • greeneroom Mar 02, 2009
    Atually the dryer in question above is  model # MDG9206AWW
    I already checked the entire discharge for a possible clog an it was clear.
  • greeneroom Mar 05, 2009
    Thanks for the input. I did end up fixing the problem myself. I took apart the dryer ,removed the tumbler and noticed the guide wheel had broken. Knowing It somehow had an airflow problem I came to the conclusion that the tumbler spinning at a slower rate was reducing the speed of the impellar thus reducing the airflow on the dryer. As a result I replaced the wheel, reassembled the dryer and now it works as if it was brand new!!
I don't know what the noise is but I had the same problem with the drying. I checks several sources because I don't like to replace parts that are not broke. the problem was 2 coils near the pilot light. Each is held on by 1 screw and a wire gets plugged into it. Easy fix and ran fine again. I think the coils are a comment problem because as soon as I told the parts place what kind of dryer I had they told me what I was in for.
Posted on Mar 05, 2009
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
The dryer has no heat when turned on.
Check your coils & igniter. Access door usually located in lower right front of dryer. Remove (pry up & out from bottom of panel, if no screws, exposing burner assembly. Set dryer for heated dry and start, you should see the igniter glow bright orange (give it at least a minute) followed by a CLICK sound,(again, a few seconds) this is the coils opening the gas valve, followed by a blue flame for heat. If no glow, replace igniter. If igniter glows bright and no click, replace the coils.
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Clothes won't dry, works sometime.
Either a bad flame sensor or bad coils on the gas valve assembly.
Jun 01, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
114 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
