Question about Motorola Mobility i880 Cellular Phone
My i880 was in my cup holder and my cup holder hade a little of water from my drink and it got wet so theres a way to fix it i kind of have my cell open half ways so what i do?
  • bcdasnil Mar 02, 2009
    hare says spesial code
  • 77 Answers
If its not powereing up, it is usually toast. also Motorola will not fix these phones , as they can tell if there is water damage.
you can try here and see if they can replace the board
http://multiplexelectronics.home.att.net/phonerepairs.html
Posted on Aug 02, 2009
How many ounces are in 8 cups of water
2 Quarts, 64 ounces
How many ounces make 8 cups of water??!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid=20110510124322AATVk3D
May 10, 2011 - 8 cups is 2 quarts or 64 ounces and no you do not HAVE to drink 2 quarts of water to be healthy. You do have to drink enough to not be ...
How many cups are in 8 ounces of water? - Quora
https://www.quora.com/How-many-cups-are-in-8-ounces-of-water
There are exactly 8 fluid ounces of water in a cup. However, that same water weighs just over 8 ounces avoir du pois. (8.3454) This depends a little on ... how many ounces are in 8 cups of water Google Search
Aug 17, 2017 | Ice Cream Makers
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
Recepies for the cactus smoothie
Some of the names of cactus smoothies are:
a. Detox Cactus Smoothie
b. Pineapple Cactus Smoothie
c. Cactus Pear Green Smoothie
d. Nopal Cactus Smoothie, etc
Nov 29, 2016 | Blenders
How do we insert the coffee pods
Open the brew mechanism. Opening the brew
mechanism will initiate the heating of the water and the
HEATING light will flash.
2 Place a clean cup on the cup stand, adjusting the height of the
stand up or down so that the rim of the cup is close to the
brew mechanism.
• To adjust the cup stand, insert your finger in the center
of the stand, lift and turn.
• To avoid spilling over, please choose the right sized cup for
the drink you are making.
3 Position your choice of T-DISC on the T-DISC holder, label facing
down. Firmly close the brew mechanism by pressing the clamp
down until it shuts. The HEATING light may flash again as the
machine heats the water to the required temperature for
your drink.
4 When the AUTO light illuminates, press and release the start/stop
button. Brewing will start automatically. There may be a short pause
during brewing; this is normal and is designed to draw out the full flavor
of your drink. The AUTO light flashes throughout the brew cycle. When
the machine has finished brewing, the indicator light will move from
AUTO to MANUAL and then, after a delay of 30 seconds, to HEATING.
5 Open the brew mechanism, remove the T-DISC and discard.
Your drink is now ready to be enjoyed.
You can prepare the next beverage right away by repeating
steps 2 - 5.
Jan 14, 2011 | Braun Tassimo Coffee Maker
My rainbow e-series canister vacuum cleaner has a horrible smell. i cleaned out the water tray and it STILL smells horrible. how do i fix this problem?
Get a new hepa filter.
It is at the back side of it, behind that rectangular cover, where the exhaust cover is. It either snaps off with two plastic tabs on the bottom of it, or has two screws on the bottom of it, and two screws behind the cord holder taps thing. If it is that kind, the cord holder tabs thing, snaps off with a flat head screw driver on either side of it. You will see the little slots on it, if it is the kind with the screws on the filter cover. Two screws behind the cord holder tabs thing, towards the top of the filter cover, and two on the bottom of the filter cover.
Always clean your water separator with a tooth brush, or Rainbow separator cleaning brush. If it has it, it is by the water separator in a special slot for it, rite there by the water separator. If not, use a tooth brush. They are just alike. The separator nut, is a half inch, or 13 milimeter size of a nut.
Thank you,
Ralph
Nov 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
The front cup holder is off track. How do I fix this?
Just did this myself.
Open the front compartment under the drink holder, lightly push to one side and then pull on the side where the crack you've just made is to disengage the clips, repeat for the other side.
When you have that cleared, remove the screws that have the face plate attached to the drink holder.
Stick your hand up in through the hole where the lower compartment was and with the other hand push the drink holder in and out, changing the angle a little bit until you can pull it free.
Nov 19, 2010 | 2007 Chevrolet Uplander LS Minivan
My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Aug 25, 2009 | Keurig Platinum B70 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Dropped my Motorola I880 in cup of tea
i had a i730 that i drop in water i took it apart an took the blow dryer set it on hi about 8 to 10 " away from the parts put it back together it work just fine till i drop it out of the window of the mail truck. yes you can buy the main board
ps the i880 is a lot easier to work on then the i730
Jun 25, 2008 | Motorola Mobility i880 Cellular Phone
Holder
wet the suction cup a little, press down firmly before flipping the switch to lock it down
Apr 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Motorola Mobility i880 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
